Reaper's Blackbird Build Chronicle
Old 07-23-2009, 01:05 AM
Reaper935's Avatar
Reaper935 has a brilliant futureReaper935 has a brilliant futureReaper935 has a brilliant futureReaper935 has a brilliant futureReaper935 has a brilliant futureReaper935 has a brilliant futureReaper935 has a brilliant futureReaper935 has a brilliant futureReaper935 has a brilliant futureReaper935 has a brilliant futureReaper935 has a brilliant future
A few have asked for a build sheet on her so here's the project scope & details:
Motor:
Andial 3.8 liter (102mm) Pistons & Cylinders (flame ringed/Al Si guides)
FAST standalone EMS w/J&S knock gaurd (100 hrs tuning)
GT2 Evo Cams
Ti Retainers
Porsche Motorsport tripple valve springs
Welded & Reinforced Heads (for 1.6 bar)
Twin plug'd
83 lb Siemans injectors
Dual t3/t4 garrett ball bearing turbos | 50mm compressors |t3 stage 3 turbine wheels |.63 a/r exhaust housing
Dual msd 7al digital ignition boxes with high performance coils
Lightweight Flywheel
Individual throttle bodies with custom plenums by TWM (to be installed when we retune the motor)
Tranny:
Stock geared 4 speed
Quaiffe 80% lockup diff
Tilton triple pate disc with custom hydraulic setup (stock is clutch cable)
Cooling System:
(1) 72 row MOCAL cooler dead center in front bumper
(2) 9x9x2.5" coolers at a slant behind each headlight with SPAL fans activated by ****pit switch
-16 line and AN fittings for everything
Suspension & Brakes:
Full RSR coilovers at 4 corners (350 lbs front springs, 500 lbs rears but we need those up to about 800 after the testing, firm but too much movement)
Torsion bar delete
Raised Spindles on the front axle by 19mm
Drop links & Bump steer kit
Derlin bushings everywhere
Upgraded rear sway bar
935 style X strut and chassis brace
935 Centerlock hubs from 1977 (require 427 ft/lbs of torque to install lug nuts)
Wheels & Tires (as restored by Harvey Weidman in Oreville, Ca):
Front Wheels - 17 x 10.5 BBS spun wheel halves using a 16 inch 20 bolt magnesium centerlock mesh center
Front tires - 315/35/17
Rear Wheels - 19 x 14 BBS e50 prototype rim halves for Porsche used by the Kremer brothers in 1981 (with KREMER stamp in the outer halves, complete with scaring from a hard life), utilizing a 16 inch 20 bolt magnesium centerlock mesh center
Rear Tires - 345/35/19 Pirelli Pzero Corsa Competition tires (heat cycled)
Brakes:
Brembo 993 Twin Turbo spec units in black
Crossdrilled rotors in standard 993tt sizes
Custom aluminum hats to fit and space for centerlock hubs/spindles
Stainless lines
Stock bias valve
Carbon fiber cooling plates for front bumper intakes
Body:
Fiberglass 935 reproduction front bumper with xenon HID's in modified H4 housings
Fiberglass 935 reproduction front fenders with hand cut louvers and vents
Fiberglass 911 RSR 15" rear quarters modified and pie cut to enlarge the opening to accept a 29.5" tall tire with enlarged skirt
Fiberglass 911 RSR 15" rear bumper slotted for exhaust and modified to match quarter panel work
Fiberglass 993 LeMans tail base with enlarged uprights
Carbon Fiber relector delete panel
Carbon Fiber 70" predator wing
Carbon Fiber End Plates measuring 12.5" wide by 20" tall
Steel hood/doors/roof
Drip Rail delete
Vitalioni Sebring Mach 1 mirrors
Hood pinned hood with 935 style aluminum cap plates
Rocker Panel delete
PPG Base Black with Flex'd n' Flat clear coat
Interior:
Alcantara headliner, rear seat delete, door entry plates, rear quarter panels
RS Carpet kit
996 GT3 Carbon Fiber seats
Schroth Profi III 6 point harnesses
Brey Krause B pillar brace & chassis stiffening system
Rennline aluminum track mats & floor boards
Rennline pedal set with split adjustable throttle pedal with heel toe extensions
Hargett 4 speed modified shifter & linkage kit
RS door panels
996 GT3 Cup Porsche Motorsports steering wheel with quick release
Upgraded gauges from North Hollywood Speedo to include:
-220 mph speedo
-9k RPM tach with playback memory
-LED conversion on all gauges
-Red faces with black letting and needles
All electrical/ignition/fans/fuel pumps on toggle switch in ****pit
No A/C
No Heat
No Radio
No sunvisors
No center console
No emergency brake
Before we started:
Old 07-23-2009, 01:06 AM
Reaper935's Avatar
Home at last...
Old 07-23-2009, 07:49 AM
Duma's Avatar
Duma is on a distinguished road
how much hp and torque?
any video?
Old 07-23-2009, 07:53 AM
Reaper935's Avatar
at 1.6 bar she's around 900 at the wheels in HP, tq is around 820
at 1.2 bar which i ran for the weekend i picked her up before the triple plate tilton let go, we were at 576 ft/lbs of tq at 4,400 RPM and she peaks at 6,500 for tq. I need to get the dyno sheets, the shop was setting the AFR's for safe running.
The dyno sheet I loaded is 634 rwhp at 1 bar and 605 ft lbs of tq
vids of us messing around:
http://www.flickr.com/photos/3329043...7621377134776/
Old 07-23-2009, 08:15 AM
Reaper935's Avatar
Old 07-23-2009, 01:53 PM
flyinbrian's Avatar
flyinbrian has a spectacular aura aboutflyinbrian has a spectacular aura about
Very Cannonball Run pre Ambulance! Nice work J.J.
Old 07-23-2009, 04:14 PM
Duma's Avatar
such a beauty......
Old 07-23-2009, 11:33 PM
L8Apex's Avatar
L8Apex Is a GOD !L8Apex Is a GOD !L8Apex Is a GOD !L8Apex Is a GOD !L8Apex Is a GOD !L8Apex Is a GOD !L8Apex Is a GOD !L8Apex Is a GOD !L8Apex Is a GOD !L8Apex Is a GOD !L8Apex Is a GOD !
Been following this on Rennlist...insane! Congrats!
Old 07-24-2009, 01:57 AM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
That's awesome! How long did the build take?
Old 07-24-2009, 01:59 AM
Reaper935's Avatar
Started in July 2007 looking just to get a 935 style front bumper...they sent the wrong one that was 3" wider per side...so it all kinda snowballed into this. So just at 23 months.
Old 07-24-2009, 03:34 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Your car is pure sex! Congratulations and enjoy
Old 07-24-2009, 04:02 AM
CarGuy56's Avatar
CarGuy56 will become famous soon enough
cool build
Old 07-24-2009, 10:55 AM
Reaper935's Avatar
Well i just finally remembered i did take a pic of the rear wheel that had the most slippage inside the tire...so enjoy the insanity and to quote Keith and Aaron at Zuffenhaus "Its an insane problem to have, but a problem none the less...we could always install a set of bead locs...hahaha"
Hard to see the white paint marker, but you can see it in the close up.
Old 07-24-2009, 01:17 PM
flyinbrian's Avatar
That last pic is nuts!
Old 07-26-2009, 03:08 PM
911TurboS2's Avatar
911TurboS2 has a spectacular aura about911TurboS2 has a spectacular aura about911TurboS2 has a spectacular aura about
That's a beautiful car, and a tremendous effort in terms of the build. Reminds me of the great days of the Porsche Turbo 935.
Quick Reply: Reaper's Blackbird Build Chronicle
