Boost Problems And Flashing CEL
Old 11-15-2008, 05:31 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
I haven't pushed it to 1.4 bar again
Just interested to hear what could be causing it
Couldn't be the DV's could it? that's all that's been changed
  #32
Old 11-21-2008, 02:29 PM
ant_8u's Avatar
Problem solved - probably
I climbed under the car to check the Wastgates
I could open one of them with my fingers without too much difficulty but the other one was a damn sight harder to open
I blasted them both with WD40 and worked them open and closed (and repeated this for a few times)
Next morning I went out in the car and went for a few hard pulls
The first few times I was still getting 1.4-1.5bar
Then all of a sudden under WOT at full boost it suddenly dropped down to 0.4bar
So, it as it turned out it was a sticking wastegate causing me to overboost and not a leak after all
I have changed my MAF too and am now i'm boosting 0.7bar spiking to 0.8bar
All is good again!
  #33
Old 11-21-2008, 04:37 PM
YOU ON a stock maf?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #34
Old 11-21-2008, 04:52 PM
ant_8u's Avatar
MAF is stock
Do you think i should change it?
Is it a problem?
  #35
Old 11-21-2008, 06:02 PM
do u have a new one ? just making sure casue I rememember you saying that you were waiting for a replacement....
9.66
click to view
  #36
Old 11-21-2008, 06:10 PM
ant_8u's Avatar
Replacement arrived today and has been fitted
Is stock ok or should I get something else?
  #37
Old 11-21-2008, 06:19 PM
as long as ur on ur current seup u have no options.... if you go up to a bigger system and the tuner runs a different maf then its part of the kit... you cant jsut install any maf and expect a car to run well...
if ur on a stock airbox you should be fine...
9.66
click to view
  #38
Old 11-21-2008, 06:27 PM
ant_8u's Avatar
Cool
Still using the stock box, so stock MAF it is then
  #39
Old 11-30-2008, 08:16 AM
ant_8u's Avatar
How do you perform a presure test?
Are there different ways/techniques?
PV=nRT.
09-09-2022 06:06 PM
proTUNING Freaks
09-15-2015 07:28 AM
oo7
09-10-2015 08:08 AM
Quick Reply: Boost Problems And Flashing CEL
