door handle
door handle
I tried to check forum to see if this was brought up before and I didn't see anything on this. I went to open my door today from the inside and herd a pop . The door still opens with handle but it feels like it has no spring to it anymore ? It even sits out a little bit ( not flush to door anymore ). Is there a spring that is supposed to be connected inside ? Or did something else brake ? And the big question, does the whole door panel have to come off to fix it? Thanks in advance for any help.....
If you end up getting it done get them to change the inner operating handles while they have the trim off, that is if your silver door handles are worn.
https://www.6speedonline.com/forums/...ng-broken.html
wouldn't it cause your windows to recess a few inches if it sticks out a bit, like when you open the door? I know the actuator is tripped by part of the actual door handle/opener (alumilook part).
You would think so but it doesn't. Everything functions just like it should except the handle doesn't have that tension on it when you go to open it and hangs slightly.
https://www.6speedonline.com/forums/...ing-broke.html
Try this link and some of the related links. Inexpensive fix if you DIY.
happened to me as well a couple of days ago. took the door panel off and it was the mechanism that is between the door handle (inside) and cable. the part cost around $12-15. and very easy to replace. when i get mine i'll post some pics
ModBargains
Lotus Vendor Classifieds
10-13-2015 03:42 PM
ModBargains
McLaren Vendor Classifieds
10-13-2015 03:41 PM
ModBargains
10-13-2015 03:40 PM
