Duramtric lower suspension
Old 11-07-2011, 04:57 PM
carreracup03's Avatar
carreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the rough
Durametric = lower suspension?
I sent a note to Durametric on a whim to ask if the Durametric tool can lower my Cayenne with air suspension. This was the response. Encouraging. I have not tried it yet ... but may this weekend. If anyone wants to give it a shot and report back, that would be great.
Thank you for contacting Durametric. The ride height of your Cayenne can likely be adjusted from within Durametric by using the "Adaptations" function of the level control module. Unfortunately, we are not aware of the exact procedure to perform this operation. We strongly suggest referencing a reputable service manual for your car. Please contact us if we can be of any further assistance.
Old 11-07-2011, 06:46 PM
es201nj's Avatar
es201nj is infamous around these parts
In the Actual Values section of leveling. You just need to change the coding and then write the changes. Lowering or lifting.
IMG_4663.jpg?t=1320716606
Old 11-07-2011, 06:49 PM
It says front wheels ... is there a section for the rear wheels. Also what does each number mean ... I guess I change the second number to a 4 and my car is 5mm lower at each level. Wow. that is a nice feature of the Durametric.
Old 11-07-2011, 07:16 PM
es201nj's Avatar
if you scroll down in the menu you will get to the rest of the coding.
If you want to lower -5mm then you would use code 14411 Then write changes.
IMG_4664.jpg?t=1320718400
IMG_4665.jpg?t=1320718401
Old 11-07-2011, 07:32 PM
Ah ... seems pretty straight forward. Have you tried it? Ride quality? Thanks very much for the info!
Old 11-07-2011, 07:59 PM
es201nj's Avatar
Yes, I messed around with it but after I already lowered the truck. I use lowering links.
Old 11-07-2011, 08:17 PM
I had lowering links. Mine drove a little too rough.
Old 11-07-2011, 08:44 PM
es201nj's Avatar
If you use the durametric/links/lowering module or any other way of manipulating the suspension you will get the same effect. No matter how you lower it 5mm, it's still 5mm no matter what product you use. With the adjustable links I can fine tune it rather then being preset to whatever a module sets it to. 5-10-15-20mm etc of lowering. Does it take more time, yes, but I dont mind
Let's say I like my ride height at 31.25 from ground to fender but all the electronic units put me at 32in at normal ride height. And in low ride height it puts me at 30.5 with electronic lowering setting. But with the links I'm at 30.75 at low setting. This is just an example.
I prefer to have an air gauge like on my custom airbag suspensions and set it at 90psi for normal driving. 85psi for little low sport ride, etc....these are tapered sleeve bags so psi could be different. Again just quick examples.
Old 11-08-2011, 11:12 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Interesting thread....what else can you do with the Durametric software? Tuning? Clearning CELs permanently? Thanks guys!
Old 11-08-2011, 11:31 AM
es201nj's Avatar
I got the Durametric and FVD Tune from Greenmotorsport at the same time. With the Durametric I flashed in the FVD Tune. Most of the service and some coding can be done.
Old 11-10-2011, 10:47 AM
I tried this last night. It seemed to work. Make sure you go into the codes section of level control.
Old 05-05-2012, 01:32 PM
dimarua's Avatar
dimarua is infamous around these parts
Fak.......
Hi, i jacked my car (2004 cayenne S) up with out turning of the air suspension & it seems to ride with the back right an inch(maybe 2) higher than the rest of the car.
so.... i am now attempting to do calibrate my suspension with the Durametric tool (6.204 software)
During the calibration process the car lowers its self then will not raise & the compressor will not engage to raise the vehicle.
The engine is off & i have a charger attached to the battery, no power low alarms, 11.6 V at the terminal.
Any advice at this point would be greatly appreciated
Cheers
Dim
Old 05-07-2012, 10:17 AM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
11.6 volts is not enough. I would start your engine and let it idle. You can calibrate the air suspension while it's running.
Old 05-07-2012, 05:23 PM
garukun's Avatar
garukun is infamous around these parts
This is indeed very helpful. Where did you guys get the codes? And their meanings? 14411 seems way too arbitrary for me.
04-28-2022 12:38 AM
danyoP4S
09-30-2021 05:06 AM
SRC4S
09-01-2015 09:22 AM
ECS Tuning - VW
08-26-2015 12:33 PM
08-19-2015 06:35 PM
Quick Reply: Duramtric lower suspension
