Notices
Cross Threaded brake caliper bolts
Old 04-08-2010, 09:34 PM
CRGT3's Avatar
CRGT3 is infamous around these parts
I hate to admit my stupidity, but as I was changing out my front brake rotors on my '07 997 GT3, I have cross threaded the bottom caliper bolt. I am scared to death that the whole hub assembly must be replaced. Does anyone know if this be tapped and repaired without replacing the whole assembly?
Old 04-09-2010, 02:13 AM
Mercedes Benz's Avatar
Mercedes Benz is infamous around these partsMercedes Benz is infamous around these parts
So is the bolt in or out now? or is it stuck?
Old 04-09-2010, 06:30 AM
CRGT3's Avatar
The bolt is out-the threads on both the bolt and the caliper block are messed up.
Old 04-09-2010, 07:04 AM
NorthVan's Avatar
I would take (tow) your car to your local dealer or independent that you trust and see if they can re tap it.
Good Luck
elh0102's Avatar
elh0102 is infamous around these parts
You might be able to chase the threads in the hub with a tapered tap, but I would guess not. You may be able to tap it for the next larger size bolt.
Old 04-09-2010, 07:25 AM
TRAKCAR's Avatar
TRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of light
If you hav not, eventually you will.
On my last GT3 I Time serted all 8. Now I am considering doing the same or put studs in. At least the rear, you haveto take the caliper off each time you put new pads in.
Old 04-09-2010, 07:30 AM
sasportas's Avatar
Awaiting Email Confirmation
sasportas has a spectacular aura aboutsasportas has a spectacular aura about
Threaded bolts
I have replaced all the thread inserts on my 997 GT3 Calipers. I've also replaced on guys with 996 TT's. I have the kit at home to perform the permanent fix. You can't re-thread the calipers, you have to use a thread insert. There is a company in NJ called Wurth Products that sells a product called TimeCerts (201-825-2710). You are going to ask for a screw thread insert kit for bolts M12 x 1.5. If you have any questions once you get the kit just let me know.
Old 04-09-2010, 09:06 AM
TRAKCAR's Avatar
I did the same thing, but I wonder now, if it would make more sense to put studs in with nuts instead of using the porsche bolts?
Old 04-09-2010, 03:45 PM
ttrew's Avatar
ttrew is infamous around these parts
CRGT3 - Don't feel stupid, as you see it happens to many of us. I was as careful as I could be, always used a calibrated torque wrench, and still stripped one of my rear uprights while changing pads.
Like the others have said, the fix is not to try to chase the threads, that is not possible in the aluminum upright. If you take it to the dealer, they will charge you $2k to replace the upright.
Either buy a kit, or take it to your trusty local independant and have Timecerts installed. Don't try coil inserts or anything but Timecerts. I wish Porsche had designed the uprights with studs instead of hardened steel threading into cast aluminum, but that is the way it is.
Old 04-09-2010, 11:11 PM
CRGT3's Avatar
Thanks to everyone for the great tip on the Time Certs. I have ordered them already. I am a bit relieved to hear that I am not the only one to have run into this problem. Thanks again.
Old 04-09-2010, 11:14 PM
were you using hand tools or impact?
Old 03-10-2011, 09:39 AM
bradze's Avatar
bradze is infamous around these parts
i did the exact same thing with the right front caliper on my evo x. installing brake duct nozzle, had caliper off so many times before, ****ing impact. ill look up time certs
Old 03-10-2011, 09:41 AM
TRAKCAR's Avatar
Happened to me as well. Added Time Serts. On the new car i went with studs and nuts, like on CUP cars.
Old 03-10-2011, 11:11 AM
bradze's Avatar
looking into time certs, a new caliper for me is $1500+, i can only imagine on a 997. now if only i could remember that my impact should ONLY be used for taking on/off lugnuts, thats what i got it for
Old 03-10-2011, 11:34 AM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
Thank god everyone is recommending time serts and not heli coils!
Another option is to pick up a rethreading kit if it isn't too terribly mashed up. Sears has a nice standard/metric kit for about 70 bucks.
The biggest advice I can give on caliper bolts is to get the caliper flush against the carrier at both the top and bottom locations, before trying to thread the bolt in. If the caliper is at any angle at all, you are going to hammer the threads. Also, thread by hand first, and when it gets tight, switch to a STUBBY ratchet and slowly turn the top and bottom in back and forth until you know both are going in correctly. If you try to just put in the top first all the way, it is asking for trouble.
Quick Reply: Cross Threaded brake caliper bolts
