997 GT3 Homelink Switch set up
My dealer ordered the 997 Homelink Switches for me so that I could hook up my garage door openers. The Part #'s are as follows:
99761322701A05 and 99761322501A05.
![](http://i17.tinypic.com/2i0916w.jpg)
![](http://i19.tinypic.com/2hxn31e.jpg)
To begin you'll need to attach wires to two of the four prongs on the back of the switches. For the single door switch, you need to attach wires to the 2nd and 4th prong (this will activate door #1). For the switch that handles two doors, you need to attach wires to the 1st and 4th prongs (this will you activate door #2).
![](http://i11.tinypic.com/2jca1vn.jpg)
Then you have find an old or extra garage door opener (the smaller the better) that you can modify. To modify, you'll have to separate the circuit board from the plastic case. Then you'll have to find the circuit that attaches to the "button" on the opener. Attach two wires, close, and then hook up with the homelink switches and then you are done.
![](http://i12.tinypic.com/47bninq.jpg)
Good luck!
Good luck!
Nice. Hmm, I didn't realize that the GT3 didn't come with them but my old 997S did.
Did these come from GMG? J/K but I did notice they made the other thread about sending the wrong spoilers disappear. That'll solve the problem
![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
switches
They are 997 Switches. The 997 GT3 does not come with homelink. Any yes, they go in the area of the map lights.
Also, I killed the spoiler thread because I did not want to give GMG a hard time - I know that they're a respected shop. And I'm sure that they have a great business and racing team. I just wanted them to work with me on what I perceived to be a simple mistake in an order.
I guess this would make it too easy but these cars were supposed to come with Homelink.
Homelink
To answer your question, there is no wiring for the homelink present. There is power to the area that you can tap into from the map lights, but no wiring for the homelink. The homelink transmitters are not present in the GT3 at all. If you want garage openers, you'll have to rig a system.
homelink
I did not add a homelink transmitter. Truthfully, a regular garage door opener works better and is easier to program. Also, my system is very light weight and doesn't involve the bumper.
![EEK!](https://www.6speedonline.com/forums/images/smilies/eek.gif)
Originally Posted by Bruce
Do you know if the factory installed the wiring for homelink but not the buttons and transmitter.
