Bilstein PSS9 for C2 and C4 on Clearance!!!
Guys our distributor has some sets of Bilstein PSS9 they are clearing out UBER cheap and wanted me to post this up to help move the inventory. I am guessing they are changing stock to the PSS10 which really is the same thing almost.
Anyways the PSS9 is a great coilover for street use. Maybe 1 or 2 times doign a track event a year. I have used these on my 996C2 that was supercharged. Very comfortable for the street. They use the factory front and rear rubber strut tops. Adjustable ride height and include a helper spring for absorbing the small bumps and lean on turns. Factory sway bar links work great or you can upgrade to our Agency Power front or rear ones. Again VERY comfortable for street driving. Adjustable dampening allows you to soften or stiffen the damper depending on your handling or ride needs.
Bilstein Porsche 996 C4 - $1699
Bilstein Porsche 996 C2 - $1799
These are instock for immediate shipping. If you are interested in our Porsche 996 Carrera Sway Bars, Control Arms, and Sway Bar Links from H&R or GT3 setup, view them all here - http://www.vividracing.com/catalog/s...=38&class_8=38
If you want to order a set, please give me a call!
99C2
Is it possible for a DIY install on these and what's involved? Also, what would a "typical" reputable shop charge for the install? I'm assuming that if I install, an alignment would still need to be done by a shop, what would that run too?
The C2 is a very easy install. About 3 hours. The C4 takes some more work cause of the front setup. About 4 hours. Check www.renntech.org for DIY. We charge about $95/hour. Alignment can be done via basic Porsche alignment for about $125 or with a full corner balance for about $400.
According to Bilstein, the C4/C4S part numbers are the same. (The TT is a different part number).
[media]http://www.bilstein.com/304passengercars.pdf[/media]
C4 and C4S are the same. My fault. So price is the same. I have them instock. Call me to order or for shipping quote.
If you are doing track events and want a better coilover, then go JIC Cross.
