Track Upgrades (PICS)
I know these have been discussed here before but its kinda slow tonight...Here's some of my winter projects:
TRG Droplinks
![](http://i169.photobucket.com/albums/u216/redridge_2007/DSC_1971zzz.jpg)
![](http://i169.photobucket.com/albums/u216/redridge_2007/DSC_1984trg.jpg)
![](http://i169.photobucket.com/albums/u216/redridge_2007/DSC_2004zzz.jpg)
GT3 RS Brake Ducts
![](http://i169.photobucket.com/albums/u216/redridge_2007/FLJ_0395zzz.jpg)
![](http://i169.photobucket.com/albums/u216/redridge_2007/FLJ_0734zzz.jpg)
X51 Oil Pan
![](http://i169.photobucket.com/albums/u216/redridge_2007/DSC_1973zzz.jpg)
Just more stuff to throw at you guys!
TRG Droplinks
GT3 RS Brake Ducts
X51 Oil Pan
the x51...helps with frequent high g's, its better than nothing (stock).
I have a c4 and the gt3 bars arent a good match... H&R are better in c4 and turbos. The Pss9 front linkage binds with the H&R on hard fast corners, hopefully these will do good on track days...Im sure it will. Here a view stock vs TRG
![](http://i169.photobucket.com/albums/u216/redridge_2007/DSC_1979zzz.jpg)
is it true that the H&R swaybars are solid comparing to the GT3 which are hollow??? what were some major differences you felt after you installed the GT3 swaybars with the PSS9s or did you do them all at the same time??? thanks in advanced...
yes H&R are solid, they are the same stuff that springs are made of, gt3's are hollow, very light, but the gt3 bars are made for c2/gt2 (rear wheel). Huge difference with this setup, the Pss9 lowered the ride and have the damper adjust...thats about it. With the H&R, there is a HUGE diff on roll, the trg drolinks will help in going faster on corners.
![Big Grin](https://www.6speedonline.com/forums/images/smilies/biggrin.gif)
Currently I am running PS2 tires 235/295 front/rear even though these are great on the street I think I might invest in some R compound tires just for the track, may be some Hoosiers R6 still investigating.
Lastly you can't go wrong with this set-up! the brake ducts I not sure if I really noticed an added benefit...but the brakes held up all day so maybe that says it all.
Originally Posted by CLS
I second the difference on the H&R sway-bars I just got back from a track day at Laguna Seca with the exact set-up your running, and I had this on my face all day
As far as your setup... how are your sways setup? front/middle rear/aggressive?
As for the brake ducts, no fading? What pads?
I believe there are also pilot sport cup tires that you can look at, heard good things about it!
Thats great, I cant hit the track till the beginning of summer so Im jonesing right now...
The front sway-bar is set aggressive, rear is set middle, firmest setting on all four corners of the PSS9s. I am thinking about the cup tires, but the PS2 are better for the street and I was thinking of having a set of tires just for the track....just thinking right now the PS2 only have 2K on them plus 4 hours of track time.
Originally Posted by delirium
CLS, you have the TRG links too? So the stock links w/ H&R sways are a no-no?
For street use I dont think the stock DL are bad but on track there are cases that they snap especially if your running thicker bars like the H&R's. Remember the stock sways are alot thinner in diam and the stock droplinks are designed for that setup.
