924/944/951/968
924 EFI Conversion
Old 06-19-2009 | 03:48 PM
Insane's Avatar
Insane is infamous around these parts
924 EFI Conversion
HI everyone,
I've made an EFI conversion and I'd like to share my experience here.
Actually, I haven't seen it mounted on the car yet, but it runs well on a dyno.
For the conversion you'll need:
- ECU and wiring harnesses
- Oxygen sensor //placed on the downpipe
- Air mass meter
- Water temp sensor //placed in the cylinder head instead of thermo-timer
- crankshaft positioning sensor and a crankshaft gear
- throttle positioning sensor // placed on the throttle body
- knock sensor //best place I've found is near the intake manifold
- fuel rail + fuel pressure regulator (I've heard that Ford Sierra '99 is suitable)
- injectors
- idle valve // placed on the place of cold start valve in the intake manifold
You will also need to machine some stuff:
- injector's fitting adapters
- fuel rail holder
- water temp sensor adapter
- crankshaft pos. sensor bracket
- crankshaft gear should be centered on the crank
- throttle positioning sensor bracket adapter
- some piping for AFM may be required
For proper set-up you'll need:
- wide-band Oxygen sensor and logger
- ECU flasher and the software (online programmable ECU is the best)
- a Dyno for the best tuning
- may be something else...
What do you get?
- no hot start problem as well as no cold start problem
- a bit more horsepower
- quicker throttle response
- fully adjustable system almost ready to accept turbo
My case is a custom EFI conversion kit built on J5.1 ECU which is used in most new russian cars and is an analogue of BOSCH ECU
so you may ask qeustions if you're doing the same - I'll try to help you
Old 06-26-2009 | 05:48 PM
CorsePerVita's Avatar
CorsePerVita is infamous around these parts
I am actually looking to do a megasquirt system for mine so i am VERY interested in this. What injectors, rail, etc did you use?
Old 06-29-2009 | 03:40 PM
Insane's Avatar
injectors are Mercedes 240cc (gray colored) and they do need adaptors
the fuel rail is made from mercedes or some ford, but it's actually custom built in my case.
I've heard Ford sierra fuel rail has same size as needed, but I'm not pretty sure.
Old 06-30-2009 | 12:29 PM
possible to do this WITHOUT removing the engine?
Old 06-30-2009 | 04:10 PM
Insane's Avatar
yes, but you will need to remove the belts and the crank wheel to put one with the gear like on the third photo.
Old 07-23-2009 | 04:02 PM
Sweet, great info thank you!
matt2ace
11-23-2019 12:38 PM
flewis763
10-04-2015 05:14 PM
ECS Tuning - BMW
09-30-2015 02:08 PM
ECS Tuning - BMW
09-30-2015 02:01 PM
ECS Tuning - BMW
09-30-2015 01:40 PM
