930 suspension upgrades
I've been working on my 87 930 and I'm thinking about upgrading my suspension. Right now everything is 100% bone stock. I'd like to improve handling for track use but this car is not intended to be a hardcore track car. Any suggestions?
Everything you need is here http://www.rebelracingproducts.com/S.../Steering.html
Top stuff and you won't find it cheaper, i have the full RSR set up waiting to go on mine
I agree about Rebel Racing. I have their Bilstein-based coilover system as well and I like it very much. I did Rebels coilovers with a bunch of Elephant Racing add-ons like camber plates, polybronze bushings, de-cambered ball joints, bump steer kit, and rear monoballs.
Just be careful- once you go with coilovers, there's a whole bunch of other stuff you pretty much have to do to make everything work right.
https://www.6speedonline.com/forums/...n-install.html
If you mean what other items you need to complete the suspension job, I would recommend talking with the guys at Elephant Racing. They can make some good recommendations.
For the rear, I would go with the Wevo/Ohlins single adjustable shock (does both compression & rebound), a coil over tender/helper spring to deal with turbo squat. This would let you stiffen the shock at the track for better handling, and soften it for the street. Works with or without coil overs. I would use the smallest torsion bar acceptable for the track, with large sway bars.
If you go to straight coil overs you will need to beef up the rear spring perches.
I used re valved Bilsteins (street/track) on our '73 targa, great for the track, but too stiff for the street.
I ran re valved bilsteins (race setting) w/coil overs on our race car, then swtiched to the Wevo's. This resulted in faster lap times due to the shock being more compliant over uneven surfaces.
'75 Carrera RS look race car
'79 930/DP935
'79 930/DP935
Ohlins suspension
I looked at the Ohlins website and more questions came up. Which shock did you use? What about the springs? Not sure how to figure out which shock and spring. Is there a recommendation of a dealer or shop that has details on the set-up for a 930?
Talk to Hayden @ Wevo, http://www.wevo.com/WevoContact.htm. The shocks are made to his specs. He will be able to help you with spring rates.You adjust the shock by turning the black **** at the bottom. They come with an adapter for the top and install like a stock shock. Here is a shot of the shocks on my race car.
PelicanParts.com
930 Turbo Vendor Classifieds
08-26-2015 04:55 PM
ECS Tuning - VW
08-20-2015 02:01 PM
ECS Tuning - VW
08-19-2015 02:36 PM
ECS Tuning - VW
08-19-2015 01:23 PM
PelicanParts.com
08-18-2015 04:01 PM
