Starting down the slippery slope - '87 930 3.3L Rebuild EFI Conversion
Old 12-12-2011 | 07:05 PM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
Originally Posted by CaptainCalf
no, I'm afraid charging to wrench would take all the fun out of it...
That is a shame. Similar to politics, the good ones don't want to run.
  #152
Old 12-13-2011 | 06:42 AM
CaptainCalf's Avatar
CaptainCalf is infamous around these parts
Originally Posted by 9Eleven
That is a shame. Similar to politics, the goods ones don't want to run.
Thank you for the kind words
  #153
Old 12-13-2011 | 06:54 AM
New Window Gaskets
I don't know what folks charge to replace old window gaskets, but it's not enough! I worked pretty hard getting the 1st one of 4 done last night on the pasngr side rear window. Installing the trim in the gasket was made easier with the use of 100% silicone in the grove to help it slide in. I may try that on the glass of the next one instead of soapy water, which helped but only a little
Old 12-13-2011 | 12:28 PM
Metric Fuel Line Fittings
I got lucky and found a local distributor of metric fuel line fittings, such as M16x1.5 to -6AN. If you need any just contact BAT, Inc. in Sarasota, FL at 941-355-0005.
Old 12-15-2011 | 09:33 AM
Strur Tower Brace
A new strut brace came in now just need to find time to bolt it in
Old 12-15-2011 | 10:02 AM
gpa311's Avatar
gpa311 is infamous around these parts
Great info
Thanks for sharing all your info.
I've had a couple of 80's-era 911's....will get a 930 someday.
Please keep posting.
GPA
  #157
Old 12-15-2011 | 10:08 AM
GPA
Will do
  #158
Old 12-15-2011 | 07:40 PM
strut brace installed
that was easy!
Old 12-17-2011 | 08:46 AM
Upholstery
Finally finished the headliner...no fun with a sunroof
Also, recovered the two rear side window bars cuz they will be reused with the RS carpet kit.
Old 12-21-2011 | 09:09 PM
more progress
Pressed in new tranny bell crank bushings & seats are in
Old 12-26-2011 | 10:03 AM
Interior almost done
All I need to finish off the interior is a nice set of RS door panels
  #162
Old 01-03-2012 | 11:55 AM
Checkin fuel system out
While checkin out the pumps I found that the front pump is toast and rear works, so a new pump is on order and I've deleted both the wiper & 3rd light, so the rear view is much easier on the eyes
Old 01-09-2012 | 01:04 PM
Pumps & RS Door Panels
Fuel pumps are back in the car and working...front had to be replaced. I also took the old overloaded oem fuel pump fuse#6 out for pump relays 1 & 2 and instead I installed an upgraded setup to feed each pump independently via two 12ga power wires running directly from the battery to each relay with their own inline fuses.
I also got one of the two RS door panels on this weekend.
Old 01-09-2012 | 06:57 PM
rear sway bar
I have 2 sway bars left and the smaller one looks like it will fit with oem end links, but the larger one doesn't look like it would fit w/o some mods. Since everything pretty much came in boxes with this project car I have no idea what the bigger bar came off of
They're both 20mm, so pls let me know whattcha think?
Old 01-17-2012 | 08:58 AM
Flag refurb
My flags/side view mirrors were looking pretty bad compared to the rest of the car, so I'm painting them.
