Is This True about A Compression/Leak Down Test?
I'm looking at a 91 964 Turbo and called a well known shop with 40 yrs experience to get a PPI done. When I asked about the compression/ leak down I was told on these 964/Turbo cars it wont be accurate, the reading will be all over the place. He also told me Bruce Anderson had a write up on this in Excellent magazine.
So where does this leave me? How do I know the engine is in good shape?
I agree w/IAPorscheDoc. Never had an issue. You could consider sending and oil sample to some place like: http://www.dalube.com/clsinfo.htm. At least that would indicate any likely significant bearing or ring issues, but the leakdown is kinda critical, I would not compromise on getting a definitive result.
I would get a compression and leak down test done somewhere else, how else can you verify the compression and condition of the rings, head gaskets, and valves, which could set you back $5-10,000 in repairs.
cgunsch
11
11-27-2015 11:20 AM
albert@velosdesignwerks
09-03-2015 11:11 PM
