So if I buy a set of Toyo R888s for the rear, what wheels do I get?
Including the tires? They are $415 each so those must be cheap wheels. The FF15s are $1300 for the pair of 20's but would need spacers and I would have to use the $550 Dunlops which apparently no one has experience with and they are a combo tire, not just track only.
I have a set 4 of 7mm RSS spacers if you end up needing them. I ran them on my 13 C2 but do not need them for this car. You can have them for free.
Well it looks to me like my best solution is going to be a full set of rims that are custom built for my car so no spacers are needed Then I can mount either the Dunlop Maxx Race or Trofeo Rs on them. That way I just store them in the garage and use a hydraulic jack to switch tires when I want to race the car. I think I will just wait a bit............................
In a way this ends up being a better solution even financially if you track the car more than once a year. Because you will get more life out of your wheels and tires and it's convenient. Remember, one track event on street tires and they get cooked. Never the same and noisy. Let me know when you're ready. We can work with you or your shop to pick a configuration that will do drag and road course. The Toyo is perfect for this and it takes the heavy weight well.
If youre looking for something to use for the road track as well, I guess I'm heading in the wrong direction with a separate set of rear wheels... but I've never had an issue with how a different set of wheels looks on the back while Im at the drag strip... its sort of par for the course.
I do know that the sidewalls of drag tires and road-racing tires are designed almost in opposite directions. The Toyo r888 is a sticky tire, but will not improve the 60' a whole lot, in my opinion. The sidewall is too stiff. It's no Trofeo, and its not even "Porsche specific" in having greater load ratings in the rear. But it isn't the shock-absorbing sidewall of a drag tire that so improves 60'. Within reason, the taller the sidewall the better for drag racing. THis is obviously not the case for road-racing.
drico
08-21-2020 11:57 PM
