:: ECS Tuning :: Porsche Service Tire Bags
Tire Totes take the hassle out of changing and storing seasonal tires. A heavy-duty shell with an easy-to-carry handle slips over the tire and rim to protect you and your vehicle from tire and brake residue, while organizing your garage. In their Totes, tires stay neatly covered and stacked until the next season rolls around. Extra-strong handle for easy transport. Holds over 80lbs (37.6kg) . Machine-washable. Rugged materials and construction for years of use. One size fits all passenger vehicles. Hook-and-loop closure for easy setup. Branded with the “Porsche Service” logo on the cover fabric. Contains 4 bags.
For more information and to purchase Click Here
Sturdy and attractive, these tire bags are a snap to install, and come with handy carrying handles. Use them to transport your wheels for seasonal tire changes, and keep them clean during off-season storage.
Click Here to order yours Today
Also don't forget to pick up a FK Wheel Tree. Assembles in minutes and with the ability to stack you wheels in the corner without the possibility of getting them scratched up.
Click Here to order your FK Wheel Tree today
FK Tire Trees will accommodate wheels up to 8 inches in width for the basic model or 11.5 inches for the Wider tires.
Don't wait, order yours today and clean up that work space
Click Here for more information.
The correct way to clean brake dust from your German made wheels. This safe PH controlled, non-acidic cleaner is approved by the worlds for-most wheel manufactures.
The Full Size E-Z Detail Brush is 18" long by 4.5" wide and it uses a sturdy handle with a built in rubber knuckle guard and bonded vinyl tip. If you have spoke wheels or other tight areas the Mini E-Z Detail Brush may work better for you. This brush is approximately 13" long and 2.5" wide and fits perfectly between even the tightest spoke wheels, engine bay compartments and other areas.
Wheel Wax is safe for all wheels, painted, anodized, polished or clear coated. Just wipe it on, let it dry to a haze and wipe it off. For maximum shine, rinse the wheels with cool water and buff to a high shine.Once you use it, you'll wonder how you got along without it.
Subtly distinguish your Porsche with these crested valve stem caps in a Silver or Gold finish.
Keep an eye on your your tire pressure with this gauge from ECS Tuning. Correct tire pressure makes sure that you are getting the most MPG out of every tank. In addition to getting fuel efficiency, you can also see a longer life for all of your tires. Cupping and premature wearing is caused by incorrect tire pressure so correct it and save yourself serious money.
Protect your expensive alloy wheels with extended reach Schwaben Protecta six-point impact sockets. Like our standard length versions, extended length Protecta Sockets have color coded mar-free exterior coatings that prevent nicks and scratches left by plain metal sockets, but reach deeper when standard length sockets just aren’t long enough.
The Schwaben Low Boy has features and benefits not found in hydraulic jacks sold by mass market suppliers. Its handsome, thoughtful design features a resting jack pad height of only 3.5 inches, letting it snake beneath most lowered vehicle chassis without the need for drive up ramps. A quickpivot single front roller lets it turn on a dime for easy navigation in tight quarters.
Made of lightweight, high strength aluminum alloy, the Low Boy weighs in at only forty pounds, and its removable jack handle and side grips makes it truly portable. Precision machined matte aluminum finish, highlighted by bright red trim and contrasting black accents and hardware make it as pleasing to the eye as it is functional.
You wouldn't go out for a night on the town wearing some busted up old shoes would you? Then don't treat your ride the same way.
ECS created this kit so you get the right tools and chemicals from the right guys, the Chemical Guys.
Kit Contents:
- Gerbil Wheel Brush
- Durafoam Tire Dressing Applicator
- V.R.P. Dressing - 16oz
- Elite Microfiber
- Clear PVC Spray Bottle
- Contoured Tire Brush
- Premium Blue - 16oz
The Gerbil Wheel Brush is safe to use on all wheels, whether they're alloy, painted, polished, or chrome.
The specially treated sheepskin construction holds over 8 ounces of soupy water or degreaser, meaning you won't have to keep dipping the brush in the cleaning bucket. This gentle yet effective brush is designed to fit into almost any hard to reach area, making cleaning faster and easier for you.
joseph_number1
07-19-2018 05:45 PM
ECS Tuning - VW
08-20-2015 02:01 PM
ECS Tuning - VW
08-19-2015 02:15 PM
