Car control during break-in
No matter what I say you always seem to find something to moan about... I'm not going to list every source or experience through which I've gathered this info/knowledge... (we're talking years here) nor am i going to argue about it.
In the end everyone has to make up their own minds from the data which is provided/gathered.
I have no intention (nor interest) of hijacking this thread.
I'll leave it at, we agree to disagree...
Manifold,
I was a chemist before law school so I am better at talking about the glass transition temp of rubber in tires than debating production specs with an M.E./Civ. E. And, you make excellent points as well.
As a lawyer, however, I often find that specifications like this are conservative, and usually for a great reason - to protect us from ourselves. If they said, just don't take it from the dealership to Daytona, everyone would just blow them off, push the sports plus button, and punch it out of the dealers parking lot.
You, Sid and Buckwheat all suggested the same thing, albeit in slightly different ways; namely, "be respectful of the engine." Like all good mechanical devices, if you take care of it, it will take care of you!
Fortunatly for me, 4200 RPM's will let me go plenty fast for normal driving, which is all I intend to do for quite a while. Indeed, my biggest problem is that my commute to work is just over a mile and so I need to take the "long way home" as short trips are just as bad as long ones.
All of your advice, and Sid's and Buckwheat's, is very much appreciated!
Not to digress too much, but the tire temp question has also been relevant to me. I got through the winter here in the mid-Atlantic with summer tires on the Porsches, but put all-seasons on the C63 (needed new rear tires anyway). I found that I was OK with the summer tires above 40F driving pretty much however I wanted, but I didn't get really aggressive until the temp was over 45F. I was also OK between 35 and 40F, even on wet roads, but always drove gently at those temps. Never attempted to drive in any snow. All of this was tied with paying a lot of attention to tire pressures to help gauge tire temp rather than just ambient temp.
I tried reading through this but it's pretty lengthy. Anyone have a link to Porsche's official stance on break-in procedure?
Few questions:
Warm up the car? Yes/No
Street driving: Should you stay bellow 4200 RPM's?
What's the minimum/maximum time the car should be driven on the streets during break in?
After how many miles can you open it up?
Read somewhere that PDK doesn't allow the driver to oblige break-in procedure. Can someone explain this?
Thank you.
Few questions:
Thank you.
The only times I've gone up over 6k is when I tried to use Sport Plus. It's barely useful for street driving, IMO. I don't even KNOW at what RPM it wants to shift into 2nd yet. I guess I'll find out after break in.
I don't understand the logic behind frequent oil changes early on, my porsche dealer said my first should be a 15,000 kms or 1 yr whichever occurs sooner. My BMW dealer had said my first should be at 10,000 kms.
Sorry to spoil the surprise for you but all gear shifts in sport + take place at about 7500 rpms. I've been using both sport and sport + from day one. Top speed achieved so far is 225 km/hr and I almost every day hit 200 km/hr at least once.
I would think the high numbers still on the road also has a lot to do with the cars being desirable and "worthwhile" to keep up, and many are babied / low mileage. It would be interesting to see if there has been a dropoff in recent years, not because of quality, but increase in sales of "regular" cars and not just enthusiast sports cars that may enjoy better care.
On the flip side, I don't think I have driven any other car with as much spirit, so there seems to be margins.
Just to add my two cents, be sure to vary your revs a lot when you're on the highway. Do whatever you can to avoid sitting at 2200 RPM for miles and miles. Shift up and down, speed up, slow down, it'll help you pass the time and give the PDK some break-in too.
Good suggestion! Thanks.
L
All the advice you have received here is good - Porsche drivers by and large are certainly knowledgeable about their cars. You should remember that it is not just the engine that needs to be broken in, it's the transmission, the differential, wheel bearings and every mechanical component with bearings and fits, i.e., coolant pumps, oil pumps, etc. Whoever commented that the factory takes it to redline several times during testing was correct, but be absolutely sure that the oil temperature is up to operating temperature before getting on it.
Varying the load and the RPMs is very important and after 500 miles, I don't think 4000 RPM is a red line that cannot be crossed safely but then again I wouldn't rev it past 6000 or above either. Cycling it through operating temperatures is also important - that helps all the bearings to get perfectly seated in their bores (they need to be heated and cooled through several cycles).
However, babying the car too much can also lead to poor oil consumption - today's engines are held to much better tolerances than even 10 or 15 years ago, but it use to be important to load up the engine after a few hundred miles to properly seat the rings - I think that it less important with today's better materials and tolerances.
I used to know the head guy at the Cadillac engine group. He once told me that the first thing you do when you buy a new car is change the oil even before you leave the dealership, the second thing is to run it hard after a few hundred miles. That advice is probably not relevant today, but if I were you I would get close to 2000 miles, certainly 1000 miles or more, before you took it to the event.
Based on the type of event this is, a beginner car control clinic, I can not imagine needing to go over 6,000 RPM. From my understanding, it is more about breaking, being lined up for turns, and recovering when and if your butt is swinging around ( less of an issue with the 991 than any of it's
predecessors), than it is about speed. There will be a fire truck there to wet down the pavement in the Giant Stadium parking lot to make a skid pad.
I would not take it to an Autocross - again, relatively low speeds, until at least 1,000 miles, and likely a lot more. It will not see a track or the sport/sport+ button used until at least 2,0000 miles (I have a lot of driving to do!)
I will have calls out to the organizers and some others who have participated to make sure that my understanding is correct. If it is even a close call, I will either just go for the classes or take the mustang. I am sure I can make that spin!
Thanks again for your advice and for looking up the schedule for the boat. You are so close - maybe in an attempt to break in both of our cars we should meet for lunch some time NY state - some place half way. We should invite any others getting their cars in March or early April.
Enjoy your St. Patrick's day. Indeed, I wish a safe holiday to all who have generously contributed there time to answering my question!
Thanks Newman. First, did you get your car yet? It must be minute to minute now. I am as excited about you and Gleek48 getting your cars as I am about getting my own (almost). Your advice, like much of the other advice I have been given in this thread is great. Other than the oil changes issue, which I intend to do early and often, I think all of you agree on the important stuff, on the first 500 or miles, and on what to do overt the next 1,500.
Wouldn't mind getting together with you and others in the metropolitan area for lunch sometime in April (preferable late April for me) and comparing notes. Would be fun.
AG991 - have not received it yet; my dealer looked it up on his computer on Saturday and it is still at Davisville waiting for its Monroney/EPA sticker. However, he seems to think that when the computer is updated on Monday that the the paperwork will be done and he is expecting it as early as Wednesday - based upon what I saw I don't know why he thinks that but he has five other cars on the same boat with all their paperwork done so he's guessing that my car will be done as well and all six cars will be arriving at the dealership this week. Unfortunately I have about 10 days of travel coming up so it will be close whether I even see the car before I have to take off - I'll be glad to get the car so I can "get back to work."
Help!
I am expecting my 991S to be delivered to my dealer by the end of the first week in April so I am under a month away. Yeah! And when I get it I can...drive like a little old lady from Pasadina for 2000 miles. The dreaded break in period. My 997.2 was gently used ( excuse me pre-owned) and I bought it with 2500 miles on it. So I could take it right to the track. But not this time.
Within about 2 weeks from the date I get it, I am signed up for a car control clinic offered by the NNJR - PCA. I have never done this clinic before, but I assume that there are a number of breaking and turning set ups including a wet-down skid pad. Speed is not a central theme and one can certainly lose it at lower revs. But can I take the 991 to this event? I certainly will not have 2000 miles in two weeks (my last only had 3,000 additional miles when I traded it in 10 months later.) I know not to track it and I will not do Autocross until I can use sport plus. But I would love to do the car control clinic in the 991. Otherwise I will use my Mustang.
Your thoughts? Thanks.
PS: I am leaving town for 10 days without receiving my car; certainly hope to pick it up the day I return!
