Cheapest and easiest way to mod the exhaust sound! I just really love it.
Holy crap I have taken apart a few things, you are on a mission
Thanks again for your help... I'll be sure to keep your ID if I need to know how to take anything else apart you wll have already done it
I'd greatly appreciate if you described how you took out the back rests for the rear seats. That central support bearing assembly has defeated my efforts so far. Thanks in advance for your help.
This central support has two pieces front/rear connecting to each other.
1st step is to remove the rear part , just lift it up from behind and this rear part should come off easily
2nd step is to remove the front part, this is a bit tricky. This part is locked to the central car body by two plastic clips and It is very tight so you need to push out the sides first then pull out toward the front of the car, I found that it is easier to do if you have remove the rear seat first.
Hope this help
My sincere thanks, jambon, for your prompt and informative response. I had gotten as far as removing the rear plastic part, but couldn't figure out how to remove the front part. Now it's all clear.
Thanks for all the photos and "how-to" remarks!
UPDATE: This thread just indirectly helped me fix a rattle that the dealership failed to fix three times. Awesome!
turbotuner20v
09-11-2015 12:02 PM
