Design issue - 991 Cab Soft top
Why Porsche changed the buttons just for the soft top functions I also don't get. Yes, i know they are mimicking a natural behavior but it's really uncomfortable to have to keep pressing the top whilst driving. Oh and putting it up it's also really uncomfortable - in terms of the usability buttons.
Gary
There is a pretty big difference in my mind between a correctly designed, engineered, and manufactured product and the "label/warning police" issue. While I completely agree that some products are worse due to certain safety issues and that there are far too many warnings these days, in this case based only on what I am hearing in this thread the interaction between the seat and the windscreen appears to be poorly designed. This isn't a warning issue, it is a ergonomics & common user useage issue. Rest assured that Porsche will fix it in a future release and likely as not provide any kind of retrofit/warranty fix UNLESS there is a safety issue. Probably missed in initial testing and the electronic cutout wiring and switching couldn't get there in time for Yr 1 & 1.5 (quite a project if they never saw this coming). Lots of things are "fixed" in manuals only later to be fixed in real life.
In this case -- I'm on the fence a little, but I have to agree with the OP that it isn't common sense to realize that the wind deflector would hit the passenger seat and cause damage. My view would be different if every car had a wind deflector and we've had a lifetime of experiences that tell us that this could cause damage (like we do with a finger in the car door, or standing in front of a moving car ). The wind deflector and its operations just aren't common enough yet to assume there will be common sense in understanding this conflict.
Good luck in the repair.
P.S. Easy software fix -- the back of the seat will move up slightly (if needed) when the top is activated (just like the windows coming down).
Just as an aside, I removed the yellow and white warning labels from the sun visors with rubbing alcohol and some patience. Soaked the area, carefully removed the edge, and kept gently peeling across and re-soaking. Took about a half hour for each side. So much better.
991, black, booster, cab, cabgear, damage, espressocognac, gear, porsche, protecting, replacement, seat, soft, top
