They overfilled the tires and under filled the motor oil
After it nagged me every time I started the car after the odometer reached 9k, I had some time today and decided to take it to the closest Porsche dealer (not the dealer where I purchased the car) for an oil change and a maintenance reminder reset. Although I changed the oil and filter at 2k and 5k I didn't want to screw with the car's computer to reset the reminder; the extra $100 over the cost of the materials or so for the service seemed to be fair for the tech's time and the dealer's facility.
Well, I was wrong. They overfilled the tires and they under filled the oil.
From personal experience, I know that draining and adding the correct amount of oil in a 991 is not that difficult of a task even for a 58 year old lawyer. It just takes care, time and one cold beer while the oil drains. Similarly, employing a tire pressure gauge and then looking up the correct tire pressure and either adding or releasing air from the tire is also a simple endeavor.
I called the service rep, asked him to confirm the tire pressure for the wheel and type. Although the TMP showed excess pressure that confirmed my tire gauge reading, I could be wrong (the Porsche manual could be outdated) and it's always nice to have expert advice on such things. He said he had to call me back. He didn't.
I called back an hour later and he said the tech was on break. I then checked the oil level and saw that it was low but still reading "OK"...I called the service manager and explained that two things never happened when I used to take by Honda to Jiffy Lube
- They always filled the oil to full and the tires to the correct
pressure; and
- They never charged $200 to do that service.
One of the more remarkable things he said (no, it wasn't an apology, he didn't) was that the $200 charge was a bargain and suggested that the dealer was losing money on this service.
I've learned my lesson...I am going back to where I bought the car - Porsche of Delaware - for all future service. They have been very good with the only vehicle problem encountered so far - a minor sunroof rattle - and they actually seem to like what they are doing and are interested in the car and their customers. It's a little far to drive from the house, but it's probably for the best.
pressure; and
when you say they under filled the oil, how many lines did you see in the dash?
I had a similar experience where i could see only 2 lines (out of 5) and they said that Oil builds up pressure and will go up when the engine is hot... Was this BS?
You can measure the oil level when the engine is off. There is no oil pressure then. One blank square is filled.
The oil level doesn't rise with pressure, but the level will rise when the oil temperature increases. Better to have the oil level a little bit low than too high. Also, many dealers fill tires with the pressure recommended for full load conditions. I think they probably do that for liability reasons since they don't know how you are going to use the car. That might be what they did for your car. Unless I specify otherwise, my dealer always inflates my tires to full load pressures of 37 front and 44 rear.
What I have seen from some of the mechanics and service managers is a lack of attention to detail, problems with communication skills or mechanical education.
A good tech and manager will actually ask you how you drive the car, how often you drive and under what conditions it's driven.
These days, with rare exception I have had more in depth conversations with bicycle mechanics about my cycle than with motor vehicle technicians about my Porsche. This may be a function of the computerization and/or "componentization" (where stuff is replaced and not fixed anymore) of motor vehicles.
Happy Thanksgiving.
Perhaps I wasn't clear since some of the comments are regarding tires.
When i took the car in for full service (10K miles) they filled the Oil Level to only 2 squares (out of 5).
That seemed strange to me - eg why not fill it to the max level?
It's physics.
