Engine stumble/hesitation around 2500 RPM?
Old 07-18-2023 | 02:59 PM
Sajan's Avatar
Sajan is infamous around these parts
I was trying to eliminate the air cleaner or the tuning flap change-over values as a cause.....especially considering all the COV related issues mentioned on the forums plus I am seeing lumpiness on the graph for air flow (could be throttle body though..)
  #722
Old 07-29-2023 | 07:09 PM
Sajan's Avatar
@Bruce in Philly
I am going to change out the camshaft adjustment solenoids to see if they make a different. my testing with a piwis has lead me to this path..
will let you know next week what happens.
these solenoids are part of the varicam triad...
  • Camshaft Actuator - 9A1-105-304-05
  • VarioCam Lift Valve Solenoid (VVS) - 9A1-105-308-03
  • Hall sensor / camshaft position sensor / variocam sensor - 997-606-106-03
  #723
Old 08-01-2023 | 11:17 AM
Bruce in Philly's Avatar
Bruce in Philly is a glorious beacon of lightBruce in Philly is a glorious beacon of lightBruce in Philly is a glorious beacon of lightBruce in Philly is a glorious beacon of lightBruce in Philly is a glorious beacon of lightBruce in Philly is a glorious beacon of light
Good luck!
Bruce in Philly (now Atlanta)
  #724
Old 08-05-2023 | 10:19 AM
Sajan's Avatar
Originally Posted by Bruce in Philly
Good luck!
No bueno... didn't solve it but now I feel like it's more obvious..
Will start with the next cheapest item from the triad lol..which is the position sensors. Browsed through the thread and didn't see anyone mentioning replacing those.
  #725
Old 06-10-2024 | 11:30 AM
axl886's Avatar
axl886
Originally Posted by runner1021
Replacing the O2 sensors has resolved the problem (at least for now) for a couple of us. Details on the RL site.
Which thread is it specifically? Thanks.
  #726
Old 06-10-2024 | 11:31 AM
axl886's Avatar
axl886
Originally Posted by stealthboy
Indeed. Following with much enthusiasm. I will be replacing mine in two weeks.
Did replacing the O2 sensors (pre cat I guess?) solved your stumbling? Thanks.
  #727
Old 06-10-2024 | 11:34 AM
Sajan's Avatar
reposting what I posted there:
well. I ordered a oil cap because I needed to drill a hole in the current one to measure the crankcase pressure...to test out the AOS.
I discovered my current oil cap is missing an o-ring! I could hear a little leak near the cap and when I held the cap tight, it stopped.
With the new oil cap (no sound/leaks), the car seemed to idle a little better when warm. Will report back in a few days after further observation.
Now here's the main point: I got a reading of -12inH2O.
According to LN engineering, the correct reading is
  • MA1 Nominal crankcase vacuum is -15.0” (-14.0” to -16.0”) of H2O (not HG).
https://lnengineering.com/products/aos.html?limit=all
so the car is driving A LOT better. the low end torque is there (and it pulls!) and the stumbles are less prominent or non-existent. I will occasionally feel it, ever so lightly but not enough for me to care.
I would even say if I didn't spend months chasing this down and had just gotten this car, I wouldn't even think there's anything "wrong".
So maybe the low crankcase pressure was the issue? My theory is that these are transition points in the variocam tech and less than ideal readings/sensor data/pressure values make them more obvious. after all, look at precise nature of these engines..
the crankcase pressure is affected by higher altitudes which probably explains why the stumble was gone when I was in the mountains..
Sam996TTS
09-12-2011 04:36 PM
911ESQ
03-20-2011 10:06 AM
dutchgirl6484
Cayenne 955/957
08-13-2009 10:23 PM
Barrister
07-25-2008 10:27 AM
