Oil Pressure Gauge
Oil Pressure Gauge
Anybody else rely on the digital readouts for the car temps n such? I tend to use them quite a bit as it's all in one spot. I did just notice that the oil pressure does not match. I did reset the car just in case it was a computer glitch, same thing.
![Name: image-1920068162.jpg
Size: 454.6 KB](https://www.6speedonline.com/forums/attachment.php?attachmentid=223302&d=1363969102)
Water and oil temp are looking to be accurate, but I was noticing there can be quite a difference with the pressure. Digital has shown 29psi while the mechanical was sitting at 20. Not sure which is correct, but I have my suspicion the mechanical is correct. I'll be stopping by the dealership to have them look or calibrate it.
Can you convert the electronic gauge to read out in the same units as the mechanical gauge?
I don't see where I can change it to match the mechanical display. I only see where I can change the display to show something else, not change the PSI setting.
It should be under the units setting.
ChuckJ
ECS Tuning - VW
09-02-2015 01:47 PM
ECS Tuning - VW
09-02-2015 01:19 PM
ECS Tuning - VW
09-02-2015 12:58 PM
