Euro tail lights with amber turn signals
I had some clear euro tail lights fitted to my US spec 991. And they work perfectly. I have an amber turn signal and all other lights function as they should on a euro model. The clip is the same fit but you need to trim off a small piece of plastic on the clip to get to slot in. Unfortunately I don't have any pics of the process as the guy that imported my vehicle changed them. But he said it was less than a 10 min job to change both.
These are the little i order:- Clear LED Rear Lamp Kit. Porsche 991 Carrera LHD Cars
CLEAR LED REAR LAMP KIT. PORSCHE 991 CARRERA LHD CARS
Code: 99104490015
Code: 99104490015
Does anyone have the part numbers for stock euro tail lights? (red lens with amber turn signal LEDs). The clear ones are easy to source but I would like to stick with the red lens.
The ones I found (99163114309 & 99163114209) supposedly don't have a rear fog which makes no sense if they are the euro market lights.
If the left tail light in your photo was blinking when you took it, you were turning. Especially if the right tail light was not blinking.
If the left was not blinking, then you were braking ....especially if the right tail light is of the same brightness and pattern.
How is this any different than any other car? Only one side blinks to indicate the direction of the turn. Both sides light up solid (or light up much brighter) to indicate you hit the brakes. Pretty intuitive. Not aware of any car with an LED reader board built into the rear bumper that flashes "I'm hitting the brakes now!"
It's a beautiful, clean, flowing design of a tail light. It would have been shame to have screwed it up with an additional light of some sort.
Not sure what your point is here.
- I'm hitting the brakes
- I'm signaling a turn
Even if the car is directly in front of you, a red turn signal can register as "braking, and one of my brake lights is out".
The ambiguity is totally unnecessary and is resolved with amber rear turn signals. Yet another reason why I like driving better in Europe.
There's ambiguity with a red rear turn signal if the car is not directly in front of you, or it's partially obscured (eg. they're in the lane to your right with a truck behind them and you can only see their left side). In these situations a bright red light can mean either of these things for a split second:
I've heard this argument before and have actively tried to reproduce the situation, yet have been unsuccessful. I completely realize what you're saying, but the fact that you're:
1. Staring at the US-spec rear light of the car, and
2. Seeing the light ON, but then immediately turn OFF a split-second afterwards,
...would give you a correct indication (at least 99% of the time) that this person is not applying the brakes steadily enough to warrant any sort of action on your part. If said person has slammed on the brakes or, alternatively, is signaling a turn, chances are that you'll notice it in time. Hell, even if they have a burned brake light, you'd notice their intention within a split-second. That split second should be enough time if you're keeping a minimum distance from the car in front of you (and not tailing him ).
I can imagine some rare instances where, for example, you're racing down the freeway going 150mph and you need to determine whether the 911 down the road (blocked by said truck) is braking or getting ready to turn in front of you. Sadly, that situation seldom arises here in the States if you're following posted speed limits.
Hi,
I've just imported a 991 from the US to Spain. I need to get the amber turn signals working to make it road legal. So i'll let you know how I get on. I've ordered some euro spec rear tail lights. I'll see if i can get them to work by rewiring or I will have to get it reprogrammed at the dealer.
