Some help with PASM vs. SPASM
What is the difference PASM and SPASM?
OK, I am ignorant and need a little education. I have a Carrera S with PDK Sport Chrono. When I press Sport Plus is that the same as SPASM (the car does say that the suspension goes to sport)? Or is SPASM a specific option? It would seem that it would be SPASM when you press Sport Plus. But the online config has PASM Sport Suspension as a $890 option. So it would seem that I do not have SPASM.
Too many darn acronyms. PSM, PASM, SPASM, SPAM, OPP, DVR, DVD…
Would someone shed some light for me?
Thank you
Marc
Thank you
Marc
Yes, on your C2S, since you have SCP, when you press the S+ button, the SPASM lights up, then if you have PSE, you can see on your PCM (unless you have GPS and a DVD or an MP3 connected through a USB) how high your MPH goes....
I'm in the same boat. Given that I am not from here, when a friend told me "he just got back from DR", it took a good twenty minutes to understand it was the DOminican Republic...
I kind of share the same doubt you have.....
But i do think we have it....
PASM Sport Suspension is the actual term. SPASM means the same thing, but is not an official Porsche term. It stands for Porsche Active Stability Management. The option lowers the car almost a 1/2 inch and offers 2 suspension settings via the button in the center console that looks like a "shock" . . . Normal and Sport. It does affect the "Sport Plus" setting (if you have it because you have the "Sport Chrono" Package on your car) by stiffening the suspension and controlling damping even further than a car without the "Sport Chrono" Package (cars without the Sport Chrono Package and the "Sport Plus" button can still have the PASM option). Hope this helps.
PASM & PASM Sport (SPASM) are optional extras on the base Carrera
PASM is standard on the "S" models. Car is 10MM lower than the base
SPASM is an option on the "S" models - $890. Drops the car an additional 10MM = 20MM total lower than the base car.
SPASM is not available as an option on the Cabs
Marc
OK the fog is clearing. So I do not have the $890 option. I still have a suspension button. So I am assuming this just stiffens the suspension but not lowers it, yes?
Thank you every one for clarifying. Now can anyone come over and get rid of the flashing 12:00 on my VCR?
Marc
the suspension button is part of the standard PASM that you have, not signifying the SPASM. Nothing actually 'LOWERS' the car as you describe. The PASM equipped cars always ride 10mm lower than standard, while the SPASM cars ride 20mm lower.
Kevin
Kevin
kes7u has hit the nail on the head. In a 911, the suspension height is unchangeable. As previously explained - standard, non-PASM suspension is the tallest. PASM lowers the car (it's always lowered) by 10 mm. If you pay extra for sport PASM (SPASM) the car will be 10 mm lower than PASM; and 20 mm lower than a car equipped with a standard suspension. Both PASM and SPASM equipped cars have a sport suspension button. That button does not lower or raise the car -- but it does stiffen or soften the suspension.
So - stock suspension is tallest, has a single setting.
PASM is lower - has a standard (soft) and sport (stiffer) setting.
SPASM is lower still, has a standard (soft, but not as soft as standard in PASM) and sport (stiffer than PASM sport) setting.
If you want a car that will actually raise or lower itself on the suspension - you need a Panamera or Cayenne with the air suspension. Those are the only Porsche systems in which the car can actually adjust its height.
DMoore
'13 C2S (with SPASM)
'11 Panamera 4S (with air suspension)
DMoore
PDCC does affect the way the body behaves in a turn - by almost completely eliminating body roll. But it doesn't affect the ride height.
DMoore
'13 C2S (with SPASM and PDCC)
'10 Panamera 4S
You all realize that reading all this is MUCH more confusing than just reading the owners manual and/or Good to Know iPad app, right? And they are 100% accurate, which is not always the case here.
Marc
