Foam Gun and Deionized Water
Old 05-09-2013 | 09:59 AM
ArashApollo's Avatar
ArashApollo is infamous around these partsArashApollo is infamous around these parts
My entire house's water system (including hose and toilet water) goes through reverse osmosis. Would I still need a deionizer?
Also, what foam gun do you guys recommend?
Old 05-09-2013 | 10:00 AM
Detroit Shooter's Avatar
Detroit Shooter is infamous around these parts
Wow really? That must be some unit. My guess is no.
Old 05-09-2013 | 10:51 AM
RIndy's Avatar
RIndy is infamous around these parts
I use Griot's deionizer. I have basalt black and have washed car with city water that has not been thru softener. The deionizer does not have a meter, so I had to buy separate meter. The total dissolved solids pre-deionizer is 150ppm. I check water after each wash(6 so far) and the reading has been consistent at 5ppm. I love the results so far. Can't imagine washing without. I just use it for rinse cycle but maybe the high TDS is doing some damage during wash.
I use Griot's foam gun. I think it works great. Is it better to rinse off foam prior to wash?
Old 05-09-2013 | 10:55 AM
Scoper's Avatar
Scoper has a spectacular aura aboutScoper has a spectacular aura aboutScoper has a spectacular aura about
Nope, RO takes care of it all. I have the same setup - whole house RO. Thing is, just make sure your hose bibs are hooked up to your house supply lines (which are fed by the RO water) and aren't connected to the well output... I am guessing that since you sound certain that the hose water is fed by RO - you're all set.
Old 05-09-2013 | 11:00 AM
Thanks for the info!
Old 05-10-2013 | 06:10 PM
I'mAllIn's Avatar
I'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud ofI'mAllIn has much to be proud of
Same here.
Originally Posted by rnl
So true. However, my wife often remarks that while I am in charge of funding she is the head of acquisitions.
We obviously married sisters!
Old 05-10-2013 | 06:33 PM
flyanddive's Avatar
flyanddive is infamous around these partsflyanddive is infamous around these parts
You can buy Pentek water filters from Amazon for a lot cheaper and do the job. I made a 4 filter system from the 10" big blue filter housing and bought the resin direct from CR. I pre-filter the water going to the resin, which greatly extends the life of it. Here's what I have:
4 of these:
Pentek 150469 3/4" #10 Big Blue Filter Housing: Amazon.com: Industrial & Scientific Pentek 150469 3/4" #10 Big Blue Filter Housing: Amazon.com: Industrial & Scientific
I simply screwed them to a piece of plywood board at the top.
The first filter is a carbon filter:
Pentek CBC-BB Carbon Block Filter Cartridge, 9-3/4" x 4-5/8", 0.5 Micron: Amazon.com: Industrial & Scientific Pentek CBC-BB Carbon Block Filter Cartridge, 9-3/4" x 4-5/8", 0.5 Micron: Amazon.com: Industrial & Scientific
The second filter is a Sediment filter for possible Carborn residue from the first filter.
Pentek ECP1-BB Pleated Cellulose Polyester Filter Cartridge, 9-3/4" x 4-1/2", 1 Micron: Amazon.com: Industrial & Scientific Pentek ECP1-BB Pleated Cellulose Polyester Filter Cartridge, 9-3/4" x 4-1/2", 1 Micron: Amazon.com: Industrial & Scientific
The third and forth filters are the resin cartridges from CR. System works really well and the resin lasts the entire year, about 100 washes on all my cars. The other filters last 50,000 gallons of water so I'll probably change them every 5 years. Entire cost is about $300 when including the resin cartridges.
Old 05-11-2013 | 09:49 AM
///armin's Avatar
///armin is a jewel in the rough///armin is a jewel in the rough///armin is a jewel in the rough
More info in this foam gun?
Old 05-11-2013 | 10:32 AM
rnl's Avatar
rnl
rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !rnl Is a GOD !
Old 05-11-2013 | 02:33 PM
ww007's Avatar
ww007 has a spectacular aura aboutww007 has a spectacular aura aboutww007 has a spectacular aura about
Sorry, excuse my ignorance but...
What is the benefit of using a foam gun over simple soap and water and a sponge/towel? Would this be in addition to the sponge/towel?
Old 05-11-2013 | 03:16 PM
kev_song's Avatar
kev_song is infamous around these partskev_song is infamous around these parts
The idea behind it is to minimize the amount of rubbing that is necessary to wash the paint. You presoak with the foam gun to loosen dirt and lubricate the paint.
Using the foam gun and the 2 bucket method of washing will minimize marring and swirl marks on your finish.
Old 05-11-2013 | 08:17 PM
rnl's Avatar
rnl
http://www.autogeek.net/foam-gun.html
They explain it too
Old 10-27-2013 | 12:33 PM
2cardinalalums's Avatar
2cardinalalums is infamous around these parts
Old 10-27-2013 | 01:00 PM
studlee's Avatar
studlee is infamous around these parts
with foam gun and di water setup can u just soak and rinse in the winter without scrubbing the car and get it relatively clean?
Old 10-27-2013 | 01:49 PM
rnl's Avatar
rnl
I use a highly lathered microfiber cloth and rinse it in two buckets of clear di water.
Quick Reply: Foam Gun and Deionized Water
