Tire Pressure Monitoring System
Does the TPMS work well?
Are the readings accurate?
I have not found a device that I can attach to the tire stem that doesn't leak air when applied and therefore give a suspect reading.
The sender is inside of the tire mounted on the wheel. The leak would have to originate with the valve and that is unlikely.
I am not sure exactly what the TPMS and computer are doing, but they seem to monitor tire pressure and match the reading against temperature (boyle's law?) such that when the tire is heated and the pressure is up the car reports that the pressure is correct.
04-28-2022 12:38 AM
horsepowerfarm
09-10-2015 06:09 PM
