Tapping noise from engine
I am on a business trip, and had a nice drive up through New England. On the last hour of my drive, I started to hear a tapping noise come from the engine, related to the throttle. I push down on the throttle at around 3000 rpms, and I get a pretty distinct rapid tap-tap-tap sound. When I let off the accelerator, it goes away.
I had a quick drive to dinner this evening in the car, and it occurred again on the way back.
Anyone experience something similar? Any idea what it might be related to? I suspect something with the valve train, like the lifter.
I'll be taking the car into the dealer in about a month to get winter tires put on, and other warranty service done. I'll likely wait until then to address it, unless someone thinks it is a significant issue.
I don't get a check engine light or any other indication of a problem.
I did some online research, and it sounds similar to a sticking valve, which is usually due to a need for an oil change. I'm at 6000 miles and over a year on the original oil, so it is plausible that I should get it changed.
is changing oil related to miles only? or is it (miles/period of time) and which comes first? i know my first service is at 15,000 KM but my car is almost 9 month old and am still far away from this milage
BTW, i got a "Service Now" message on the cluster last month, took it ti the dealer and without checking i was told its a programming thing and they only reset it
is changing oil related to miles only? or is it (miles/period of time) and which comes first? i know my first service is at 15,000 KM but my car is almost 9 month old and am still far away from this milage BTW, i got a "Service Now" message on the cluster last month, took it ti the dealer and without checking i was told its a programming thing and they only reset it
oddjob142
08-19-2015 12:27 PM
