spacer help
Old 05-09-2014 | 10:45 AM
socalsteve's Avatar
socalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to all
Originally Posted by shaytun
I have H&R 7mm front and 15mm rear on my C2S. Perfect stance. Doesn't stick out. Hubcentric. There is no difference in driving feel and also no vibrations whatsoever.
Same here, identical set up...only I don't have an "S"...just a lowly base model...
Old 05-09-2014 | 11:01 AM
ECS Tuning - Porsche's Avatar
Originally Posted by willyspub
Perfect! Thanks. Placing the order now.
Awesome. Thank you for the support
Old 05-12-2014 | 05:54 AM
Robsc2s's Avatar
Robsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to beholdRobsc2s is a splendid one to behold
Originally Posted by ECS Tuning - Porsche
They are 14x1.5 with R14 ball seat, as all Porsche bolts are. Shank length is 50mm (35mm threaded length), which is 5mm longer than the original 991 bolts for vehicles without spacers.
Purchased your 8 & 10 mm spacers. Will the above locking lugs fit? What are the measurements of the 8 & 10 spacers lugs( shank)?
Lastly, do you offer same style/size lugs in brushed silver?
Old 05-12-2014 | 08:19 AM
Thank you for the support. The above locking bolts will not fit. They will only work with spacers from 3mm to 7mm.
10mm - Threaded portion is 42mm, with 57mm total shaft length.
8mm - Threaded portion is 37mm, with a 52mm total shaft length.
The only other option we have are the H&R wheel bolts, for more information Click Here.
Old 05-13-2014 | 02:00 PM
Christophosphorus's Avatar
Christophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to beholdChristophosphorus is a splendid one to behold
Does anyone have pictures of their PASM (non S-PASM) 991S with 7/15mm spacers? I'm about to pull the trigger on a set of these, but I'm afraid that 7/15 may look too aggressive on a non-lowered car.
Also, anyone with a 7/15mm setup tracked their 991? Tommyboy's comment makes me think twice about running this setup since I track the car.
Old 05-13-2014 | 07:15 PM
kitw's Avatar
kitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud of
I ran the 15mm rears on my C2S and loved them. (Sport PASM)
My C4S has 7mm front (Brey Krause so they have the split centering ring) and they're great. I re-used the same hubcentric 15mm spacers on the rear. (Regular PASM)
ID:	374252   Click image for larger version
Old 05-13-2014 | 07:18 PM
kitw's Avatar
Originally Posted by tommyboy214
... but I was worried the 15mm would give me trouble at the track while loading up the suspension in the corners.
I wouldn't worry about this - the 15mm spacers are almost all hubcentric so no additional loading. Ironically, if the 7mm spacers are not hubcentric (most are not, unless they use the split centering.) you'll have more loads on the smaller contact area of the hub centering protrusions.
These (or a similar design) are the only ones I would use, I could not get the other brands of 7mm spacers to not vibrate. (which is why I didn't have them on my C2S)
Old 05-14-2014 | 05:55 AM
HotHonda's Avatar
HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !
7 & 15MM from Adaptec....both hub centric. 7MM also have countersunk
holes for additional screws - like OEM 5MM.
Boldgt
03-23-2016 11:07 AM
djhill
10-29-2015 07:04 PM
DYL 911
10-01-2015 02:47 PM
Pcar991
09-29-2015 05:20 AM
Quick Reply: spacer help
