PDK shift lock continuous clicking problem
Old 07-06-2014 | 02:01 PM
DKC's Avatar
DKC
DKC is infamous around these parts
My 2013 C4S has recently developed a weird problem and I wonder if anyone else has any knowledge about this.
From my understanding, the normal behaviour is this:
PDK, if in neutral, cannot be shifted into D unless you step on the brakes due to the shift lock. So with PDK in N, you can feel a slight click if you lightly step on the brakes to indicate lock release, and if you lift off the brakes you'll feel a click to indicate lock engaged.
This clicking should be at the very top of the brake travel.
Weird behaviour:
In addition to the normal clicking at the top of the brake travel, I have another double-click at about 1/4 of the brake travel down.
So basically if I start wit the PDK in N and brake fully depressed. As I lift off slowly, the PDK lock will do a double click when I'm 1/4 from the top. As I continue to lift off, it will then do the normal click at the very top.
Additional weird behaviour is that if I hold the brake at about 25% depressed (eg at red light) the PDK lock will sometimes actually continuously click on and off rapidly, with a rapid vibration and sound from the PDK stick.
Any ideas?
Old 07-06-2014 | 02:09 PM
John's 991's Avatar
John's 991 is infamous around these parts
That is an interesting behavior. I don't feel two clicks or rapid vibration with my 2012 CS2 with PDK. If it is something you can reproduce, I would take it to the dealer to check out at some point. At least for the vibration, not sure the double click is a big deal, unless it is causing the vibration somehow.
Old 07-06-2014 | 02:24 PM
DKC's Avatar
DKC
Yes it is something I can reproduce so I'll certainly get the dealer to look at it.
It seems to me that somehow there is a new "trigger" point at about 25% of brake depression. So if I hold the brake at just the right spot, then it continuously triggers the PDK to lock/unlock.
However this trigger point from the brake only affects the PDK and does not cause the engine to restart (when engine is shut down due to auto-start/stop).
Old 07-06-2014 | 03:29 PM
dux's Avatar
dux
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
Sounds like a faulty sensor.
Old 07-07-2014 | 01:55 AM
bccars's Avatar
bccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant futurebccars has a brilliant future
no noticeable click(s) on my pdk !
MAcarbon
03-06-2017 08:16 AM
MAcarbon
08-24-2015 03:26 PM
MAcarbon
08-20-2015 03:02 PM
MAcarbon
08-19-2015 06:22 PM
MAcarbon
08-19-2015 04:52 PM
Quick Reply: PDK shift lock continuous clicking problem
