Trouble opening drivers door
Last Friday I got my car back from the dealer, they replaced one of my A/C condensers (bolt on highway hit it). They also did a couple service bulletins, reprogram my PDCC, a vacuum line, and I don't recall what the other was (maybe the PCM), anyway the transmission shifts faster from a stop, no hesitation now. I had to re-adjust my clock so something was done.
Anyway, normally after driving and shutting off the ignition I can just open the door with one pull, but on three occasions I pulled the handle 3 times before it opened. Yesterday it worked fine at work and when I got home, but this morning it went back to 3 pulls. The first two pulls seemed like nothing happened except for the window going down/up slightly.
Anyone experience this before?
Maybe play with the door lock/unlock settings in PCM to see if has any effect - I believe you can change it to lock on ignition start vs. drive off. Maybe something got confused in the software update (since you said you had to reset your clock).
I would definitely get this looked at right away as that's a pretty serious safety hazard.
It was a service bulletin, I have the invoice at home and can provide more info later.
I know why dux asked, and I am very interested as well. Any more info on this would be fantastic.
won't be able to get into the dealer until tomorrow or Friday for the reprogram of the doors, but here's a list of things they did:
Complete WE02 per TSB - reprogram instrument cluster and code to factory settings
Product Update WE07 - Replace cover for door arrester
Complete WE12 per TSB - Install updated vacuum hose to sport exhaust actuators (part # 000-043-209-37 vacuum line)
Complete WE18 per TSB - reprogram PDCC control unit
My sport exaust has not been sounding very 'sporty' lately. Almost no pops and burbles. It is a deeper tone then when it's off though. Was thinking of calling the dealer. Could it be related to this vacume line? I have a 2013.
When they fail they won't throw an error code.
Numerous threads regarding the death of PSE and this (PCNA) known issue with these valves.
Apparently this $40 part is not worth replacing on their flagship product..
Take it in and get it covered under warranty.
RobbieRacer - Thanks again for the info.
nlakind
11-06-2015 10:15 AM
RallyBird
10-07-2015 01:20 PM
pshep138
09-01-2015 09:45 AM
