Rear Decklid Emblems
Old 09-22-2014, 11:47 AM
Compukidd's Avatar
Compukidd is infamous around these parts
Thumbs up Rear Decklid Emblems
Hi....I am having a hard time having to detail the lettering on the back of the car all the time. My car is black and it always looks crappy around the lettering. I am thinking of removing all the emblems and polishing it up. Anyone one else experiencing the same frustration? Any detail tips? Anyone remove the emblems? Thoughts and suggestions greatly appreciated.
Old 09-22-2014, 12:15 PM
dux's Avatar
dux
dux is offline
dux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond reputedux has a reputation beyond repute
Removing them permanently?
How about using a Dremel with a soft cotton attachment at low RPM's to detail around the letters? That should do the trick.
http://www.dremel.com/en-us/Accessor....aspx?pid=423E
Old 09-22-2014, 12:23 PM
STG991's Avatar
STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !STG991 Is a GOD !
A microfiber sprayed with Merguiar's Quick Detailing spray should do the trick. Wipe the outlines of all badges. I've never had issues keeping the paint around them clean.
The only cars I see with this problem are ones that go through automatic washes.
You have to be detailed and gentle to not catch the letters and pull them up. It will take like 30 minutes to do it right. After that, if you keep up on it it should stay clean.
DO NOT use any sort of electric tool.
Old 09-22-2014, 12:43 PM
Compukidd's Avatar
Thank you. I always use the Meguiars Quick Detail spray too! Do you think removing the letters takes away from the car?
Old 09-22-2014, 12:47 PM
stealthboy's Avatar
stealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud of
I use some quick detail spray and a microfiber towel. I form a little tip of microfiber to get into the small openings. Mine's always looked clean around the lettering. Yeah, it's a pain, but not impossible. Then again, I have some obsessive traits that make me detail everything on the car.
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
I use a soft toothbrush
Old 09-22-2014, 12:55 PM
Compukidd's Avatar
I'm like you when it comes to the car. Thank you! Do you think removal of the emblems takes away from the car?
Old 09-22-2014, 01:01 PM
Pez D. Spencer's Avatar
Pez D. Spencer is infamous around these parts
If you take them off, you can easily put them back later.
Old 09-22-2014, 01:04 PM
STG991's Avatar
Don't take them off. Looks very plain.
If you do take them off there's a whole can of worms there.
Stick with them, and just be a neat freak about cleaning. All should be good!
Old 09-22-2014, 01:06 PM
STG991's Avatar
And nothing abrasive like a tooth brush! Last thing you need is scratches that are impossible to remove without having to take the badges off.
Old 09-22-2014, 01:13 PM
Compukidd's Avatar
thank you STG958.....I find the paint to be soft and the black shows everything!. I guess i'll just stick with them and detail them out.
Old 09-22-2014, 01:20 PM
STG991's Avatar
Soft is putting it mildly. Just came off a Basalt Black Cayenne a while back. It was a nervous breakdown with every wash. This was with 2 buckets, 2 mitts, and rinsing after every swipe of the wash mitt.
Went with GT Silver on my 991. Sleeping a bit easier now. Ha ha. Still needs a lot of care obviously, but a bit more forgiving.
Old 09-22-2014, 01:29 PM
stealthboy's Avatar
I personally would not remove the emblems. I like the silver script against the dark grey metallic paint of my car.
Old 09-22-2014, 01:35 PM
I always take the plastic writing off my cars. When my C4S gets here I'll debadge it before I get it Opti-Coated, then if I decide to put P O R S C H E back on it I'll get the black letters from Suncoast. I'll be Carmine Red with duck tail. Wonder how it would look with a Porsche shield, similar to the one in front, on the back? Somebody must have done that before.
Old 09-22-2014, 01:46 PM
Compukidd's Avatar
there is a lot of empty space when de-badged.
Quick Reply: Rear Decklid Emblems
