View Poll Results: Does your 911 stumble / hesitate
Voters: 98. You may not vote on this poll
Engine Stumble Poll
#122
Thx Mad max.
It would be very helpful if other non-stumblers took 2 minutes to complete the survey and help their fellow brethren get to the bottom of this issue.
Data is key.
Thanks again.
Data is key.
Thanks again.
#124
#125
I just took an extensive drive focused on light/moderate acceleration from 2000 to 3000 rpm and steady state driving near 2500 rpm. No stumble/hesitation/vibration. Nothing. Normal, Sport, Sport+, no difference. All gears, no difference. PSE on/off, no difference.
2012 C2S 7MT SC PSE, 4100 miles. Build 03/12.
Filled out the survey. Good luck to those that have this.
Given that this issue has happened in every Porsche model since Vario-Cam was introduced, but only to a small percentage of each iteration, I'm going to say data is NOT the key and this is a purely random fault.
#126
Thanks for taking part in the poll, but could you also please complete the brief survey is located at; http://www.sogosurvey.com/k/RQsRVUSWsRsPsPsP
Survey completed
#127
Much appreciated.
I hope our other brethren will also be as generous with their time.
04-28-2022 12:38 AM
r_matt_6
10-08-2015 06:07 PM
titannero
Audi
08-31-2015 01:33 PM
