Introducing the solution for 991 wind buffeting noise: The AWE Tuning Foiler™ Wind Di
Anyways - for the price I doubt this is a mod I will be making, regardless of whether I would have to take the door panel off or not. I do have to say though that the install instructions provided by AWE are quite good considering what I've seen from most vendors.... great detail with photos provided for each step in the process to remove the interior panel.
Hi all, quick follow up on the topic of installation time.
If you do see the now famous “bolt” when you remove the triangle trim, installation should take under 5 minutes per side.The instructions should get you there no problem, but if there are any issues as you go, don’t hesitate to reach out (performance@AWE-Tuning.com or 888-565-2257).
See page 2, figure 2. http://www.awe-tuning.com/media/pdf/..._deflector.pdf
If you don’t see the the bolt, the installation will take you roughly 20 minutes per side, and that includes removing the door trim, and everything else.
We engineered this part to install just like the factory part (no double stick tape, etc.) and even in the worst case scenario this is still truly a DIY - designed for simplicity. Hope that helps! Here for other questions...
I have a 2012 and a little nervous that I am going to have to do all of this. I bought it before seeing that it could be more complicated.
Just curious. If I do not have the exposed bold, can you drill a hole to expose it? Then not have to remove the interior panel.
Marc
Marc
So, didn't cancel your order? Honestly, I don't think the procedure to remove the inner door panel is really that risky or hard -- just take your time. I've had nearly all the interior trim pieces off in my '14 and totally doable by the "novice". Just word of advice is to use nylon trim removal tools, and take your time! You don't want to break-off or lose any of the smaller tabs or pins that hold everything into place. And definitely follow the instructions for disconnecting the battery which renders the airbag triggers inactive. I haven't done so myself, but I've done this a bunch of times.... you don't want a face full of trim because you happened to trigger the airbag!
Good luck! And take some pics! Thanks!
Not included but you can buy a set at any auto parts for about 10 bucks
The kit looks to come with two "adapter" styles of a sort. One is straight and one is bent.
The instructions seem to show that if you have the exposed screw you use the bent ones and if your screw is hidden then you use the straight one.
I suspect that this is done so that AWE can make one version of the foiler that works for all cars, instead of two completely different parts for the different conditions.
AWE - Please feel free to correct me if I am wrong.
Just finished the install of these. Some notes for those of you about to do it, or thinking of getting them.
1. Very easy install. Way easier to remove the doors on a the 991 than a 993 for example. Once I got to the second door it literally took me 2 minutes to remove safely. Just don't lose the little self tapping screws that come with the kit. I dropped one. Couldn't find it, and then had to fabricate one from something I had in my garage - PITA! But my fault too.
2. You can shorten the time considerably by not totally disconnecting the door panel from the handle cable. I let mine carefully hang. Alternatively you could prop them up with a small stool or bucket.
3. It was a tad difficult to get the foiler to properly grab onto the upper tang when installing. I was careful and took my time. Just be patient. One trick you can try that worked for me was to install without the lower clip and screw so you get a sense for how the upper tang engages the foiler and how much pressure you need to apply to seat it properly.
Once you do that, put the clip and screw back on and try again. Once I got to the second door I didn't need to do this trick and I was able to slip it right on the first time.
4. CAUTION: The most important part of this install IMO is when you are screwing the T20 self tapping Torx screw back into the panel and into the clip on the foiler. If you over-torque you might strip it. Just get it snug.
They look sharp! Excellent quality CF IMO. Worth the $$$ now that I see them and what they look like on the car.
Thanks for the sticker and lollipop guys!
Correct.
I had the same initial question, but looking at the instructions it appears that that won't work.
