Oil Level Indicator on very low
Old 04-09-2016 | 03:58 AM
Michael_s's Avatar
Michael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant future
You are fine. Don't overthink this. just add oil. Find Mobil 1. It's around.
Maybe some gas too!
Old 04-09-2016 | 04:14 AM
todd92's Avatar
todd92 is infamous around these parts
Originally Posted by PorscheCrazy
I'd stick with mobile. You should not mix brands.
What kind of oil is mobile? You can mix oils all you want, by specification oils must be cross compatible. The only thing that matters is Porsche A40 approval. If that's on the label, it's fine. Wal-Mart sells Mobil 1 0W-40 and Castrol 0W-40, both Porsche A40 approved, both for $23 for a 5 quart jug.
Originally Posted by solrac6262
I'm more concerned since I was trying to get an oil sample, but I couldn't get any, looks like the thing is empty if this was the case, am I supposed to get a freaking warning sign of low oil? Or do not drive, dealer all ways mentions this cars have like 1000+. Sensors hummm
You were trying to get an oil sample? So you removed the drain plug on the oil pan and nothing came out? Is that what you are saying?
Old 04-09-2016 | 07:29 AM
stealthboy's Avatar
stealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud ofstealthboy has much to be proud of
Getting a sample? How?
Did you lose all your oil somewhere? Did you do an oil change and forget to fill in some new stuff? This all sounds very mysterious.
Old 04-09-2016 | 08:10 AM
PorscheCrazy's Avatar
I stand corrected.
Old 04-09-2016 | 10:47 AM
todd92's Avatar
The mixing oil myth is a common misconception, perpetuated by the type of supposed gurus who will say something to the effect of; "I don't recommend mixing oils because of possible additive interference". Then, this nonsense gets requoted ad-nauseam and here we are.
Old 04-09-2016 | 01:44 PM
DJSArcade's Avatar
DJSArcade is infamous around these parts
This thread motivated me to check my oil and...yikes, it read "Min level reached!" Strange because I've never gotten a single warning or complaint about the oil level from the car.
I added a quart of Mobil 1 0W-50 (confirmed the Porsche A40 approval first) and now it's green and happy.
Thanks, thread!
Old 04-09-2016 | 02:42 PM
solrac6262's Avatar
solrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to all
If it is green, you are still OK. If display turns yellow, then you need to add oil immediately. If red, then its bad news.
thanks Porsche Crazy, I add 1 qt, I'm going to drive and get new measurment, I'll go from there
Old 04-09-2016 | 04:41 PM
CSK 991 C4S's Avatar
CSK 991 C4S is infamous around these parts
I'm at 45K and the 13 C4S has never used (or needed) oil between changes unlike my previous Audi's.
Old 04-10-2016 | 07:08 AM
cairo94507's Avatar
cairo94507 is a jewel in the roughcairo94507 is a jewel in the roughcairo94507 is a jewel in the rough
I am amazed we have owners who apparently do not check their oil level on a regular basis. Granted newer cars do not use oil like the older Porsches, but oil levels and tire pressure should be checked regularly.
Old 04-10-2016 | 07:18 AM
todd92's Avatar
I'm still waiting to find out why, "I was trying to get an oil sample, but I couldn't get any".
Old 04-10-2016 | 07:19 AM
todd92's Avatar
And in a 991, you don't have to leave the drivers seat to do either!
Old 04-11-2016 | 04:52 AM
ChuckJ's Avatar
ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !ChuckJ Is a GOD !
Walmart has Mobil 1
ChuckJ
Old 04-11-2016 | 11:46 AM
DJSArcade's Avatar
I keep the TPMS display as my default. I had no idea oil was being consumed though, and really would have expected some kind of message from the car that it was low.
Old 04-11-2016 | 02:03 PM
you will get a low oil warning at the yellow or red level
Old 04-11-2016 | 02:42 PM
DJSArcade's Avatar
Well, when I went to check, it -was- yellow and read "min level reached." But I never heard a peep about it until I checked.
Quick Reply: Oil Level Indicator on very low
