3WD|KW HAS for 992 Carrear
BRAND NEW RELEASE:2020+ Porsche 911 (992) Carrera incl. S
MSRP: $1,259.00
Info@3wdistributing.com
Front Height Range: 20-35mm (0.8-1.4in)
Rear Height Range: 15-35mm (0.6-1.4in)
Coupe + Convertible, 2WD / 4WD,
works with PASM sport suspension
Part Number: 25371084MSRP: $1,259.00
RIDE HEIGHT ADJUSTABLE
Configure the Ride Height to your needs
KW coilover suspensions, KW height adjustable springs, and KW DLC Air Suspensions allow the suspension to be lowered within the vehicle's technical limitations. For example, our Street Comfort products allow for a customized ride height setting with mild suspension lowering from 10 - 50 mm, while the Street Performance products allow the maximum technically possible suspension lowering range from 45 - 85 mm, depending on the vehicle. This means that the suspension can be lowered to suit the personal needs of the user and, depending on the product category, a setting ranging from Comfort to Performance can be chosen.TRAPEZOIDAL THREAD
The Perfect Height-Adjustable Coilover
In comparison to common coilovers, KW uses a friction-optimized trapezoidal thread which is less sensitive to dirt and requires less force to adjust. Its large cross-section also provides a higher load-bearing capacity.
3W Distributing LLC
5140 Rogers Street Ste C
Las Vegas, NV 89118
Website: www.3wdistributing.com
Facebook: 3wdistributing | Instagram: 3wdistributing
#1 BRABUS Dealer in North America | TECHART Authorized Dealer
Authorized Distributor for: BRABUS, TechArt, StarTech, BBS, Mansory, BREMBO, KW Suspension, H&R, Ohlins, FI Exhaust, and Much More....
WE SHIP WORLDWIDE....
3W Distributing LLC
Las Vegas, NV 89118
GMP Performance
BMW //M
12-02-2016 12:01 PM
ModBargains.com
07-06-2010 05:39 PM
