EVOMS Project 993TT GT650 (650HP) - Engine build, TiAL GT28's, EVOMSit = WOW
What is a comparable KKK turbo to the GT28's?
The GT28's can flow more air as compared to the KKK 24's. They actually have a smaller and more efficent turbine wheel which significantly reduces turbo lag when compared to the K24's. The GT28 turbos are good for more than 720 HP.
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Interesting stuff about the ECU. Couple of questions:
1- Is this running on fixed boost (through the wastegates) or does the tuning have the capability for variable boost according to load/RPMs/density
2- It still has stock camshafts?
How is the car running, any performance figures out there?
Nice work EVOMS.
Can you please post a dyno sheet of a pump fuel run? Does 650HP work out to something like 550WHP on your dyno?
No need for Twin Plug heads at this power level
Attached is the dyno. In an ideal world I would have installed some different cams in this engine and perhaps installed a twin plug system. I think twin plug is great but not 100% needed at this point. There are so many ways to modify one of these engines and it all comes down to dollars, sense and application (intended use of the vehicle). We could have added $15K worth of other components to this build which would have had no affect on the final power. Every engine build is different and the final result was developed around the customers budget and built around the way he drives the car. This is a 100% purely street car and will not be driven on the track. If the scope of the project was more for the track, we would have recommended twin plug, nirosist rings, cams, additional oil cooling, titanium retainers, race valve springs, etc. Hope this helps!
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
For this application I eliminated the OEM boost control functions. I am using an external electronic boost controller to operate the boost portion of the ECU. There are many different ways to control the boost in the factory ECU based on load, RPM, etc. I chose this route due to the easy operation and ability to change the boost settings from in the car.
Still running the stock cams timed different than stock specs.
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Hellp Rob, I will send you a PM with the details. Thanks
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Could you please post the GT650 dyno chart with the boost pressure plot?
Jean,
