993 Turbo This community is about the last air cooled twin turbocharged Porsche 911. Model year 1996 - 1997. Also inclusive in this forum is talk on the final 182 Porsche 911 Turbos built in 1997 known as the Turbo S.
ECU flash problem...car will not fire
Old 03-10-2010 | 07:04 PM
sandyclinic's Avatar
sandyclinic is infamous around these parts
Sent ECU to reputable company to be flashed...sent back to my mechanic to install and car will not fire....took ECU out again and sent to be re-flashed or corrected...put back in car...still will not fire...my mechanic is "baffled"...any ideas?????...He has checked all the relays etc and car ran fine before the ECU was remapped....Thanx....Steve C 97 993TT
Old 03-10-2010 | 11:58 PM
Basal Skull's Avatar
Basal Skull is infamous around these parts
Hi, Sorry you're having problems. You need to borrow an ecu / get a spare one to check / see if your car will start with a different ecu. BTW if you can't find a 993tt ecu, a NA ecu will start a turbo/our cars, it just won't be able to control the boost but for trouble shooting a NA ecu will apparently work. Good luck.
10-06-2015 06:13 PM
10-02-2015 02:23 PM
Quick Reply: ECU flash problem...car will not fire
