993 Turbo This community is about the last air cooled twin turbocharged Porsche 911. Model year 1996 - 1997. Also inclusive in this forum is talk on the final 182 Porsche 911 Turbos built in 1997 known as the Turbo S.
Tires inner shoulders gone
Old 10-12-2011 | 11:11 AM
Psoncanada's Avatar
Psoncanada is infamous around these parts
I took a look at my rear tires about a month ago, and they were fine (or at least that is what I believed at the time). When taking a close look at them this weekend the inner shoulder on the rear tires were all worn down and the steel threads were sticking out. Any idea if this is a common phenomena or if I should be looking at any settings that might have gone wild? The car is a -96 TT.
Old 10-15-2011 | 09:04 PM
carmstrongLS1's Avatar
carmstrongLS1 is a glorious beacon of lightcarmstrongLS1 is a glorious beacon of lightcarmstrongLS1 is a glorious beacon of lightcarmstrongLS1 is a glorious beacon of lightcarmstrongLS1 is a glorious beacon of light
Same thing happens to mine. How many sets have you been through? Also sometimes depending on model this is the reason for Porsches "N" rating on model specific tires. Each model car has a specific "N" Rating. You should look into this when purchasing them. Its difficult to understand the classifications and Porsche sometimes has changed very little in the model to designate this rating. Sometimes speed. Sometimes weight distribution. Sometimes transmission and suspension types.
Tires for your car (and mine) are Bridgestone Pole Position S-02 N3 I believe. Very expensive too.
Old 10-16-2011 | 12:47 AM
GT3 Chuck's Avatar
Administrator
depending on how much negative camber you have in the rear this is usually where these cars wear the rear tires the quickest...however, if your rear toe setting is off you will burn the inside edge even quicker no matter what your rear camber setting is...get the alignment checked when you put on new rears
PV=nRT.
09-09-2022 07:06 PM
danyoP4S
09-30-2021 06:06 AM
WheelB
991 Turbo Vendor Classifieds
07-23-2018 10:37 PM
oo7
09-10-2015 09:08 AM
gabe325
911
09-02-2015 09:10 PM
