700hp 993tt
700hp 993tt
Hey guys, just thought you might like to check out this 993TT we are finishing up. We are just dialing in the last settings and road testing - the car is a beast!! Elecromotive engine management, custom hybrid Turbonetics turbos and a lot of custom fabrication.
The engine was fully built, with GT3 oil pump, JE Pistons, Pauter Rods, Twin Plugged heads, Custom Ground Cams, Larger intake valves and other tricks and tweeks along the way. It's running an Electromotive TEC 3 with a custom tune. The owner is just out having a blast with the car right now, hoping to do some final adjustments and then get it on the dyno for final power numbers in the spring. Boost right now is moderate at app. 1.1 bar.
