any1 think i should get spacers?
ive got 18in fikse fm10s, no rubbing issues or anything, just asking from an aesthetic perspective. Any opinion on which ones to get?
http://picasaweb.google.com/Ricky.Nardis/991WFikses
nice suspension and youll be where you want to be.
S
S
Lower ride height doesn't have to mean a bad ride. Some PSS9's or similar coilovers can provide just as good of a ride as stock units.
I bought/use them on my car to prevent rubbing issues. Not sure I'd use them for aesthetics only.
AFAIK...RUF uses them on all of their 911's. No bent rims that I'm aware of.
No the most likely factor relating to bent rim will be amount or sidewall rubber,sidewall strength & improper tire inflation. As said above the lowering with good coilovers will result in a much better ride all around..handling and comfort.
Believe all Fikse's are custom made therefore there is no "standard". If they are "spec'd" for standard OEM offset then that is a different story. You will still need to determine what the offset is then you can determine if and how much spacer you need. I do have a pair of slightly used H&R spacers that measure 11/16".
Hope this helps.
Hope this helps.
