Durametric or Brockway R920 ?
Old 10-14-2007 | 12:06 AM
pgcanillas's Avatar
pgcanillas is infamous around these parts
I need your help on this. I want to buy an OBD2 signal decoder in order to know what is happening inside my motor. The durametric seems an excellent tool because it allows to datalog, but the R920 is always inside the car, so you can check it whenever you want, plus allows to monitor the 2 Wideband o2 readings. They are both more or less the same money, so which one should I choose? Thanks!!!
Old 10-14-2007 | 06:35 AM
Mikelly's Avatar
I have zero experience with the Brockway. But I do have the durometric scanner and I'm very impresses with it. The data logger is just so handy to have.
Mike
Old 10-14-2007 | 10:35 AM
Zuma 911's Avatar
Zuma 911 has a spectacular aura aboutZuma 911 has a spectacular aura about
I haven't used the Brockway either. I have the Durametric Enthusist ( 3 cars max). I am totally impressed with this unit. Last week I had a string of three "codes", including the MAF. I was able to resolve the problems, and "clear" the codes....now shes running sweet. Even though my car is still under warranty, the nearest dealer is 30 miles away so I'd rather fix things myself if at all possible... Durametric helps me do that. good luck with your choice.
Old 10-14-2007 | 01:21 PM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
I have the Brockway and I'm very happy with it,works perfect and it has the 2 Wideband o2 readings...
pwdrhound
11
11-25-2015 02:18 AM
Frank ( Sunnyside )
Bentley
10-04-2015 12:13 AM
pwdrhound
09-25-2015 06:25 PM
jdbaker
09-19-2015 11:34 AM
arhim22
09-07-2015 09:49 PM
