colorinc & budman take DIY pe 650 for maiden voyage
Old 10-15-2007, 04:06 PM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
Thumbs up colorinc & budman take DIY pe 650 for maiden voyage
so we put our 50/60 break in miles on the new set up no oil leaks all the guages seem to be looking good switch on the boost controller and start adding boost WOW get the high boost set 1.25 bar this thing pulls so hard!! its crazy i would like to say thank you to todd k for your help and knowledge i think we have a c6 z06 killer
here is a list of all the things we did
protomotive k24/18g turbos
protomotive ecu tune
gt2 intercoolers
denso double platinum plugs
greddy profec b spec 2 boost controller
5 bar fuel pressure regulator
v-flow intake
evoms dv's
torco mach series accelerator
thats all for now
tim
Old 10-15-2007, 04:47 PM
Dutchboy's Avatar
Dutchboy is infamous around these parts
Man, I was checking out your install thread and just realized that you are in Grandville. Small world. Congrats on the upgrade.
Old 10-15-2007, 07:21 PM
buddyg's Avatar
This thing pulls hard! I can't believe it even runs much less how good it runs. Remember we did this in Tim's garage without a lift and we are not mechanics. Incredible.
Now we just need to do some testing against the RED BEAST I think it is going to be closer than I will like!
Old 10-16-2007, 11:34 PM
JWC's Avatar
JWC
JWC is offline
JWC is infamous around these parts
Hey what happened to the other thread about this "650 impressions" or something like that?
Old 10-16-2007, 11:57 PM
Get a AFR guage on that baby... that way you always know what your doing.. especially when you have a boost controller.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 10-17-2007, 12:00 AM
Alex's Avatar
Alex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant future
Would love to see the results of that comparo.
On the 1-10 scale, how difficult was the install (10 being hardest)?
Old 10-17-2007, 05:40 AM
buddyg's Avatar
Actually wasn't that bad probably a 5? We had some help installing the FPR and boost controller the rest was pretty easy.
Old 10-17-2007, 06:41 AM
WOODTSTER's Avatar
Buddy,
Very cool of you to help! Good job guys and let us know how it runs.
For starters, go out and beat that Western Michiganer with the 600 bike.
MK
Old 10-17-2007, 08:54 AM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
gt2 intercoolers
v-flow intake
evoms dv's
thats all for now
tim
Hi Tim, on mention of a clutch upgrade, I assume you are running on the stock one, any problems yet? Also at your higher boost setting, 1.25 what octane are you using? BTW congrats on the upgrade
Old 10-17-2007, 09:06 AM
O-Ace's Avatar
O-Ace is infamous around these parts
If you're running 100-octane race gas, I would up the boost to 1.30 bar.
-Awais
Old 10-17-2007, 09:21 AM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
Hey Buddy,
Why don't you fly out here and help me install my setup. I got the same one from Todd.
Old 10-17-2007, 09:24 AM
colorinc's Avatar
checking them out at sema waiting to see the new brockway engineering until then ill play it safe
tim
Old 10-17-2007, 09:28 AM
colorinc's Avatar
alex i would say it was a 7 the most difficult part was the removal of the frozen oil lines after that it was ok just a lot of work
tim
Old 10-17-2007, 09:41 AM
colorinc's Avatar
hey mike
i am running the stock clutch and no problem from the research i have done the stock clutch should be ok upto 600 bhp as long as you not launching it hard all the time. at high boost i am using 93 oct with the torco mach accelerator race gas concentrate i also did a ton of research on that product and its working perfectly
tim
Old 10-17-2007, 09:53 AM
hey mike
tim
Run that by Todd- I do not think he will like that. I personally would not with additives. don't you have 100 or 103 octane?
9.66
click to view
Quick Reply: colorinc & budman take DIY pe 650 for maiden voyage
