help removing rear arch liners?
I've removed all the screws and fasteners and the rear section comes out easily enough but i can't get the main section to budge! Is it just a case of a bit more brute force to get it to start moving or is there a technique to use? All help/guides appreciated
to remove the forward/main section of the rear wheel liner(after all hardware is removed) pull the inner side down first to help get the outer side away from the quarterpanel lip. if you have rolled this lip removing this liner will be more difficult. once you get the liner away from the quarter it will get easier to move and will come out pretty easily.
TX, i didnt forget about you, you will have that e-mail this afternoon.
04-28-2022 12:38 AM
09-01-2015 03:16 PM
