Need Help Removing Brembo Brake Pads From 6 Piston Monoblocs
I have the caliper removed from the rotor and cannot figure
out how to get the two pins and the clip off in order to remove the
brake pads and replace them. I have the 6 piston Monoblock
Brembo kit (fronts) from Vivid. .
Please let me know how these pins come off as they seem to spin
and do not unscrew ???
Marty
612-247-2270
Marty
612-247-2270
yea you n eed to tap them out. get a small object to help you do this. (i used the phippips tip of a screw driver). put it to the side of the pin and take a hammer and tap the screw drivers other end with the hammer slowly pushing the pin forward and out. the pin goes out only one way, cant remember, but youll see. once the pin is out the clip comes off.
Thanks Guys,
S-351 (Bryant) was nice enough to drive over and help me out.
He/we also cleaned my car and removed the 190 mph texas bugs, etc. It was a mess!
New pads in, full of MS103, ready for for some fall drives.
MK
MK
04-28-2022 12:38 AM
2lflat4
11-18-2019 05:05 PM
