Upgrading turbos, staying with GIAC Programming
I see ........didn't realize that was common practice......always thought of stage 3/4's as running k24's.
I don't understand Suman...........so you had turbos and programming from 2 different kits?Why make the blanket statement that all stage 3-4's run lean if you were running turbos and programming not designed for one another or was your programming changed for the ZC turbos?I know all stage 4's are not running a lean condition otherwise we would see alot of blown motors around here.
Stage 4 program and UMW made turbos. Yeah was a weird set up I thought also but it was an option(less lag etc.). I seem to not be alone in this combination. Unfortunately not a wise decision I realized afterwards. and the car secondly was too slow lol. And my statement clearly shows that I was referring to the giac programming with these hybrid turbos and not the stage 4 package from EVOMS. I hope anyone that wants to go stage 4 to stick with the stock k24's because they are designed for them. This thread has sparked interest in running hybrid turbos with tunes not designed for them, hence my input.
S
Even kevin at UMW did not recommend this mix. Heck, 3 years ago I had K24s with FVD ecy stage 4 and he convinced me to get his stage 5s ZC with proper ECU.
2001 996TT 3.6L and stock ECU
Guys.. I am all mixed up when you speak Stage 1-2-3-4-5-6-7-etc.... Can someone resume as if using the k16/k24 hybrids with giac X50 program (k24 pump mode) will make the engine run leans ?
x50 tuning is not meant for k16/24's. Its only meant for K24 straight turbos. I do not suggest hybrids with this program regardless of the tuner. If you want hybrids get a custom tune. IMO
S
S
Most stage 3/4 cars do run on the lean side because they are more or less out of injector at that point. Every k16/24 hybrid or k24 car I have logged has been near or above 100% duty cycle on the stock injectors... Even a 5 bars doesn't do enough on some cars.
Now "lean" is relative, I would like to see these cars running in the low 12's a/f near redline. This is not possible on most set ups, because there is just no resolution left in the injector.
Thanks for all the input. And, I think that the bottom line is, anything other than just upgrading to K24's, I need to do a custom tune, and my GIAC is out the window.
If I am correct with that, I am much clearer now. Just have to decide if 24's are good enough, or if I need to step it up to run with the big dogs!
I bought John D's old set up (k16hybrids w/FVD stage 4)
I added:
Ported stock headers
GT 2 IC's
Evo v flow
Forge diverters.
Fabspeed GEN 3
Suman; do think I need a 5 bar? Let's ask George to put on Dyno and see what AFR are?
Car feels really strong and smooth.
Elliot
I added:
GT 2 IC's
Evo v flow
Forge diverters.
Fabspeed GEN 3
Elliot
Elliot def have George check out the AFRs on the dyno. Its crucial to make sure your not running lean at the top of the rev band. I would hate to see something happen even though Im sure your set up is fine. Doesn't hurt to pay 100 bucks for a few pulls to save you thousands in the long run.....
Jag
What I thought we would do is Tim on high boost and me on low boost at 1.3 bar which is a typical GT700.
Then all out for both. I think he will be very close on my low boost and I should pull him on my high boost.
Any way you cut it his $10,000.00 system is hanging pretty well with my $45,000.00 system!
Well, I had his stage 5s and they were something close to I think the current stage 2s.,... he didnt feel comfortable selling me his turbos without the GIAC tuned ecu.
I picked up Adam's Speed Gallery's k16/k24 ZC turbos and will get them install shortly by Speed Gallery. Right now I'm running stock k16s on a stage 2 GIAC flash. Sounds like I'll have to get a custom tune as well? I also have an exhaust, evo intake, diverters, GT2 intercoolers, and ported OEM headers.
