My mechanic has a question on installing the AEM AFR gauge.
He did not install it saying something about with my straight pipes he would have to drill a hole in my headers to make it work? How have you guys with the AEM guage installed it?
5 inches outside your turbos right onto your straight pipe. You will be fine I actually have mine 2 inches off the turbo because I have cats and they need to be pre-cat to properly read. Straight pipes you just need them right on the pipe itself which is alot cleaner then putting the gauge on the header.
S
S
AEM recommends at least 12" from the turbo outlet. You should see this in the instructions that came with your gauge. I however run mine just a few inches from the outlet and have not had a problem.
Dont know why he would put in the header
Mine is about 8 inches away .
2001 996TT 3.6L and stock ECU
tropicatango
10-14-2015 11:32 PM
