A New Age in Tuning!- Factory Launch Control (video inside)
#46
I am just sharing my experience after bouncing between 3 tuners till I got one that can do what I wanted him to do.
good luck,
markski
2001 996TT 3.6L and stock ECU
#48
If you have access to a turbo car with a boost gauge, sit in it, start it up, rev it up, you'll see that the boost will probably go to 1psi-3psi and then drop. Then try to press the pedal with more force you'll see that it builds a little bit more boost, however recedes, now try to apply that same pressure and hold the rpm at a certain level, it will have no boost.
#49
What is the difference between bringing the revs to 3500 in the garage versus bringing them to 3500 at the drag strip starting line? I don't think you'll see boost at either location.
What you may not be seeing is that we generally need some load on the engine to make boost. You may be able to create some boost under unloaded conditions (free reving in the garage or the on starting line) by retarding the timing to the point that some of the combustion occurs in the headers. That should move combustion heat closer to the turbos.
Jeff
Jeff
#50
I don't understand how this would be beneficial if the driver can't control it on the spot at the track............what happens after the second round at the track and the sun is out and now the track is hot so the 4200 rpm launch is now bogging.........do i need to have my tuner at the track with me or can i change it myself?....If yes then this would be the ticket to some quick E.t.'s
#52
Obviously I am over my head. Oh brother.
So if you sit at the start line, time the tree and simultaneously apply gas, feather the clutch and pull away the car will not boost until its past 3500? If that is true your car is a flaming POS.
I don't see any point in being able to hold the car at lets say 4500r's and dumping the clutch and properly launching the car by simply revving it while simultaneously releasing the clutch. Its the exact same thing barring the fact that the latter requires talent.
Like I said, sounds like you guys should have gotten a tip.
#53
i rev my tt viper to redline with no boost or maybe 1psi max but my boost gauge reads over 10pis on low boost settings when its underload
#54
and please refrain from posting in what has been a very interesting thread.
- chuck
#55
So how exactly does this tune build boost in the absence of any load on the engine? If it is more than just a throttle-to-the-floor rev limiter set to 6000 rpm, what other tables are modified? I guess significantly retarding the timing would put a lot more heat in the exhaust. That should help spin up the turbos some. What else is there?
Jeff
Jeff
- chuck
#57
what happens guys, is that ignition timing is severly retarded which causes the combusion not to happen in the cylinders but in the turbine housing. Also A/Fs become very rich, so by not burning the mixture in the cylinder and dumping extra fuel, well that mixture when it touches the HOT turbos ignites and makes the turbos spin.. Hence they create boost when the car is under no physical load.
A small example: http://www.youtube.com/watch?v=pHo8Hfn-8mA
#60
