A New Age in Tuning!- Factory Launch Control (video inside)
Ok guys! So finally out of the woodwork comes some new talent in the custom tuning world. Here is a little teaser video of what a smart brain and the Bosch ME7.8 can do! Attached is the link to factory "2 step" launch control for any of you drag racing nuts out there. This is the beginning of a new era! EPLabs.net will tune my porsche and has already tuned all my high HP Audis. ENJOY!
http://www.eplabs.net/pub/996launch.MOV
When we are dealing with major HP it is not practical to have an OTS(off the shelf) program. I feel a custom tune is the way to go to precisely dial in all modifications.
S
S
I guess I am missing the point. How is this different from a factory rev limiter when the car isnt in gear. Many cars have a lowered red line so the car cannot be overreved out while the car is stationary. Also, I dont think I would like the revs bouncing around like that at the drag strip. I guess I would just prefer to do it my self. At the end of the day, it is still dependent on clutch control. Good luck with the tuning though, looking forward to the results.....
hey guys this might help explain it to you better! thanks
S
http://en.wikipedia.org/wiki/Launch_control_(automotive)
S
Suman, I understand launch control. Is this rpm control or launch control? LC is a very comples process involving much more than just rpm. It is usually working in concert with clutch modulation, throttle control, igniton, timing, etc to seamlessly provide the optimum launch for any given grip level. Is this going to do that ?
I think your thinking of elements of traction control. This is strictly to find your sweet spot at the line to dial in a launching RPM which helps out cars with larger turbos. You will be fully flooring the car when slipping the clutch.
S
Good luck with the project....
I'm also thinking that this sounds more like the normal drag racing 2 step rev limiter rather than Veyron-style launch control. The first limiter step is set for the revs you want to hold waiting for the tree to count down, the second step is the normal, don't blow the engine rev limiter.
I'm hoping it works by withholding fuel rather than spark. I've never liked the idea of squirting a WOT-load of fuel into the cylinder knowing ahead of time that you don't plan to ignite it with the spark plug. I know the intellegent spark-based limiters vary the sparkless cylinders, but all that unburned fuel on the cylinder walls and in the exhaust system can't be a good thing.
Jeff
Jeff
The point of this is to take off the line with boost so you dont bog down. 2 step is just that. I have an Evo8 with 2 step and I can build 20 psi at the light. The idea is to take off the line with boost( especially with big turbos). Can you build boost with with this set up? if so can you show it to us... Otherwise you seem to be doing some sort of RPM control as KPG stated... My car already did 1.6s 60 fts. with gt35rs an no launch control of any sort. I dont want to brake anymore axles... and I have a feeling guys will if on stock axles...
Hope it works out for you guys...
markski
markski
2001 996TT 3.6L and stock ECU
S
S
