High pitch sound (clutch)
Old 10-22-2007 | 06:20 PM
BLKM3's Avatar
BLKM3 is infamous around these parts
The previous owner installed a lightweight flywheel and some sort of clutch (I am not sure which one) and at low speeds 1st or 2nd gear, the car makes a really noticable high pitch sound. The sound immediately goes away when the clutch is pushed in. This sound only occurs at low speed driving around 10-15mph. The clutch seems to be alright. Any ideas to why this is happening?
Old 10-22-2007 | 07:17 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
t.o bearing ... but the noise should go away when clutch is out and come on when clutch is in
Old 10-22-2007 | 07:35 PM
Y65MPH's Avatar
Y65MPH is infamous around these partsY65MPH is infamous around these parts
There is a problem with the power steering pump. This is a know problem. There is a TSB on this and a very good post about it on Rennlist. Also get it fixed right away as it can cause a nasty engine fire when the pressure switch lets go.
Craig
Old 10-22-2007 | 09:22 PM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
yes. exactly wat y65mph said. power steering pump.
Old 10-22-2007 | 09:34 PM
BLKM3's Avatar
Power Steering Pump? Everything is fine with the powersteering. Its the clutch that is hard and then soft. When the sound is occuring, by pressing the clutch in, the sounds goes away completely. I don't see how that can be linked to the power steering??
Old 10-22-2007 | 10:02 PM
GT3CS's Avatar
GT3CS is infamous around these parts
The clutch actuation is hydraulic, driven by the same pump as the power steering.
Old 10-22-2007 | 11:56 PM
BLKM3's Avatar
Any idea on the cost to repair this?
Old 10-23-2007 | 05:39 AM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
I have the same problem now and I had the delar ordered one for me about US$270. You may get cheaper in US.
Old 10-23-2007 | 07:49 AM
GBG's Avatar
GBG
GBG is a jewel in the roughGBG is a jewel in the roughGBG is a jewel in the rough
BLK: This will answer most/all of your questions.
http://forums.rennlist.com/rennforum...hlight=whining
Old 10-23-2007 | 10:18 AM
BLKM3's Avatar
Just what I needed! Thanks a lot for your help!
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
Quick Reply: High pitch sound (clutch)
