Still getting inconsistent boost maybe bad diverter valves?
Old 10-25-2007, 05:31 PM
WOODTSTER's Avatar
Buddy:
I/C's
Blown Six
EVOMS
Speed Gallery
Protomotive
As always it depends on the eventual goal.
Good Luck!
MK
Old 10-26-2007, 08:30 AM
buddyg's Avatar
Turned down gain to 10% set start boost at 1.0 bar this morning 50 degrees third gear hit 1.56 with a steady 1.47. Will try at lunch to see if I can repeat.
Old 10-26-2007, 10:58 AM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Buddy,
I think it's possible that nothing is wrong with your car. Temperature affects the boost on any given setting. When it's cooler, you will boost higher (morning and night at this time of year you will see higher boost than mid-day). The way to use the Greddy is to set it for the conditions at the moment. If it's really hot, you can turn it up a bit until youi get the desired high boost. When it's cold, you will have to turn it down a bit to stay at the same level. Or you can set it so that it's as high as you want it when cold and then it will boost a little less when hot...
Old 10-26-2007, 11:00 AM
I agree, If I had the car for a day I would figure it out.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 10-26-2007, 12:02 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
the only problem is that hes at 98% with only 1.5bar on a 55 degree day. Something else is wrong. I think he might have to tighten his wastegates on his turbos. Im pretty positive he doesnt have the newer gt700 turbos. He should have way more leeway on that controller.
S
Old 10-26-2007, 02:16 PM
buddyg's Avatar
S
My GT700 is only a year and a half old. When we turned the EBC completely off it would still boost 1.35 bar. We took out the diverter valves and cleaned and greased them. Thought it was working as I started to boost 1.56 in 3rd gear with 1.47 sustained then the more I drove it I could only get 1.33 again?
It has to be something in my ECU, boost leak or my stock intercoolers can't handle it?
I don't know?
Old 10-26-2007, 02:27 PM
Highhats's Avatar
Did u swap boost solenoids with your buddy, colorinc. try that out! I hear alot of people get bad greddy's right out of the box.
S
Old 10-26-2007, 02:39 PM
Highhats's Avatar
Only reason I said your turbos may be different is because when I look at the evoms graph you stop making power at 5500 rpms. My car kept making power past 5500 to redline. Also My car had considerable boost creep(24 to 26 lbs, 2 lbs of creep). And your car is tapering off. With the small turbine housings its inevitable to have some creep even with straight pipes. I think you might have installed it wrong. Contact Markski and make sure all your wires are hooked up the same way. Not saying you F'ed it up but it just doesn't sound right. Unless your whole greddy unit is bunk!
S
Old 10-26-2007, 02:46 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
This is what makes 6speed great! So many people trying to help one another out. Keep it up and good luck Buddy.
Robert
PV=nRT.
09-09-2022 06:06 PM
Rguy
04-12-2020 11:11 PM
sparks
09-08-2015 03:03 PM
ECS Tuning - VW
09-08-2015 12:54 PM
shifter_
09-08-2015 12:07 PM
Quick Reply: Still getting inconsistent boost maybe bad diverter valves?
