PE 650 First 60-130 7.25 sec Good News Bad News
so it was a nice day yesterday buddyg and i took a afternoon cruise to Mexico fired up the v-box and pulled a 7.25 sec (with a 2xx lb buddyg and a full tank) 60-130 verified by KPG and posted in the 60-130 post yee haaa
Bad News will be putting in a clutch tomorrow i guess its a good problem when you need more clamp force because of H.P.
so next week will get a better run at it ill kick buddyg out of the car run the gas tank down to about a 1/4 and hopefully pull a mid to high 6 ill keep you posted
tim
tim
Good for starters...
how did u do it? what gear did u start with? at what RPM?
2001 996TT 3.6L and stock ECU
Tim , great run. You need skinnier friends. I have some back to back data from a bone stock Z06 and the runs were done consecutively with a passenger and without. 9.1 sec with a guest and 8.5 without. You are an easy 6sec run without the Budman. Be safe, Kevin
Post #3 is a C6 z06. Driven by a board member who knows how to drive and has one of the fastest TT's around.
tim
tim
you definitely need it with the upgraded power.
Airjordan,
Protosport does all the work on my car too. What color is your car? I don't think I've seen it there.
Raudel
Tim's car pulls very strong and as soon as I sort out my issues and he gets his new clutch in we are going Head to Head!
You are going DOWN TIM!
started in 3rd 40 mph one shift i think next time ill try 2nd gear short shift to try to get in the boost alittle more in third
tim
tim
umm hey todd can you send me the intake/injector kit
jk
tehehehhehe
jk
tehehehhehe
good luck,
markski
tim
tim
Wow! That was a very impressive run! My friend's 997TT in Taiwan with mod from Swiss tuner upgrad a set of bigger VGT, exhaust, and ECU which cost about US$24,000. His 997TT tip was running 100km~200km for only 7.5 sec. Your time was awesome! Tim did you run it with pump gas or race gas? Congrats! I think I may have to speed up my porject to get your kind of perfromance soon.
