FVD ecu flash: alive and angry
#32
What kind of diverter valves should I buy ?
#33
Get the FVD ones they are a great deal and work well, I am sure they are made by someone else for them. I love my FVD product, so much in fact I am going with their 3.8 Kit and rods. I am not going with their Turbo's I want to use some GT30's or bigger
In a stage II car this is what I believe it should be: ECU flash , BMC filter, DV's air Filter , and some sort of free flowing exhaust.
#43
Another issue is the head studs... I hear problems with those too...
Ask around... see how many FVD 3.8s are running around in the US...
Like I said, all 3.8l build had problems... and probably some still do... so whoever does your work make sure he did it successfully before your build...
good luck,
markski
2001 996TT 3.6L and stock ECU
#44
I HAve a very close long term relationship with FVD as well.... with that said, I would strongly advise you that FVD does the motor in that case and that they make it right in case it doesnt work out the first time.... From waht I hear all the 3.8s that have been built to date had problems - ALL of the them... I believe it was the liners... I also hear that the other problem is the head gasket as no one makes the 3.8 L gasket.. so the 3.6L are used and more issues arose... IDK I'm just passing on the info...
good luck,
markski
good luck,
markski
